Timing issue??
Old Oct 22, 2015 | 09:57 AM
Lookout1979's Avatar
Lookout1979
Default Timing issue??
1990 Coupe, l98, automatic, 72k miles.
Just had a minor tune up done on the vehicle - it still had the original plugs, wires, and dist. cap. After the tune up the car was running great, drove it roughly 110 miles back home with the A/C turned on. No misses or stuttering on the interstate. When I got back into town I noticed a very prominent miss when the car was stopped and A/C off, almost like it wanted to stall out but didn't - just a surge, and only happens when the car is stopped - I'm a little stumped?? All OEM parts were installed - AC Delco plugs, wires, dist. cap and rotor - did NOT replace ignition coil and was told my plugs were actually in pretty good condition being 25yrs old but the wires of course were terrible as was the old dist cap (hole had burned thru to the rotor. Has anyone had this issue? No SES light on, runs great with no misses or hesitation while 'driving' just while idling in Drive, Neutral, or reverse. It was not doing this when I drove it out of the garage, started doing it after the drive home off of the interstate.
Old Oct 22, 2015 | 10:23 AM
Vic'89's Avatar
Vic'89
If it's a timing issue, you would have noticed it right away.
There could be a new issue , injectors , fuel filter , throttle body ?
Vic
Old Oct 22, 2015 | 11:42 AM
Kevova's Avatar
Kevova
If you had at a shop take it back. If not review what you did. Plug wires fully seated on both ends and not too close to manifold, vacuum leak(s), Throttle body carboned up?
Old Oct 22, 2015 | 11:57 AM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Originally Posted by Lookout1979
Just had a minor tune up done on the vehicle - it still had the original plugs, wires, and dist. cap. It was not doing this when I drove it out of the garage, started doing it after the drive home off of the interstate.
I would look for plug wires routed too close to the exhaust that are melted/shorting. Easy to find in the dark, hood open engine running....you'll see a "light show".
Old Oct 22, 2015 | 01:15 PM
Lookout1979
I did have it done at a shop, however, it was family - and I was charged next to nothing, so I don't want to complain or even say there is a new issue - I think the 110 mile drive home has jiggled a plug wire or two loose, that's the only thing I can think of - and it does seem he routed things not exactly the way they were in the beginning. I twisted one of the plug wires (driver side back plug) and it wasn't stalling out but still had a bit of a 'miss'
Old Oct 24, 2015 | 05:00 PM
Lookout1979
Alright, went thru all of the wires, no shorts, everything is routed correctly... and this is what it's doing after the tune up - getting progressively worse - now it is constantly stalling unless one foot on gas one foot on brake - could it be a fuel filter clogging up? There was supposed to be a video attached, if it didn't upload, here is the link:
Old Oct 25, 2015 | 05:12 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Seems like it's running fine until you put it in gear.
it could be fuel pressure -that is an easy enough test.
Could you also rig a spark tester and observe spark as it's stalling? Coil wire would give you a better view.
Old Oct 25, 2015 | 07:38 PM
pologreen1's Avatar
pologreen1
Check the dizzy and the plug on the dizzy; usually cars changing under load from N to gear can be a vacuum leak too.
Old Oct 30, 2015 | 04:14 PM
Lookout1979
In response, it's actually not running fine while the car is in idle, surging up and down UNLESS a/c compressor is 'on'... still misses and surges but won't die (will die if A/C is off). It took 4 starts just to get it back into the garage earlier. I'm wondering if this is the fuel regulator or fuel filter still - but just so coincidental right after new plugs and wires. I cannot find any vac leaks at all. The HVAC line has been plugged, cruise still works perfect, but, that whole system needs to be refurbished - speaking of the climate control, and it was that way before the tune up, i'm just stumped.
Old Oct 30, 2015 | 05:01 PM
aklim's Avatar
aklim
Have you started diagnostics yet? What is the fuel pressure? Pull the FPR hose off and see if you smell gas. Get your hoe off and see what you can get for pressure. Should be around 45psi give or take? Hose back, do a WOT run, what is the pressure? Should drop off some and hit a steady number. After shutdown, does it hold pressure? That will determine the shape of your pump. You might even have to take the pump out and find out if the sock is full of crap.
Do you have a scanner? Engine off and key in run and depress the gas pedal slowly. Does the voltage go up smoothly? In 1990, the TPS start point is where the voltage is when the key is turned on so monitor it only. No setting. Should be around 0.5 to 0.7, IIRC. When the engine is idling with everything off, what is the IAC count?
Old Oct 30, 2015 | 05:51 PM
Lookout1979
I do thank you for the input, but, have a feeling this will be a take it to the shop thing - I do have a scanner but only the basic one that blinks the SES for codes - no codes stored. I do not have the garage space, tools, etc to truly figure this out, I just don't get why it was driveable other than a small miss due to 25yr old plug wires, minor tune up w/ wires, plugs, dist cap and rotor now I can't even get it out of the garage
Old Oct 30, 2015 | 06:10 PM
Pa'svette's Avatar
Pa'svette
St. Jude Donor '16-'17-'18,'19
Did the shop set the idle when they did the tuneup and was the a/c on?
Old Oct 30, 2015 | 09:46 PM
aklim's Avatar
aklim
You do NOT have a scanner. You have overpaid for a paperclip which is what I would use to get codes only. http://www.corvettebuyers.com/c4vettes/codes.htm
I suggest you get a scanner not a code reader. that way, we can help you better instead of throwing parts and money at it. Even if you have to have them do it, if you know what you are asking for, you can't be so easily bent over.
Old Oct 30, 2015 | 09:47 PM
aklim's Avatar
aklim
Not sure if they can set the idle unless it is completely cranked out of the ECM adjustment range. Again, he needs a scanner to see what is going on.
Old Oct 30, 2015 | 09:59 PM
Lookout1979
Understood - now I see why they wanted the 100.00 to 'scan' it. i'm used to OBDII readers that give a bit more info- so yes, wasted money when I should have just taken it to the shop to see what was going on - even if it's foreign language to me I could give better input. Just frustrated right now to have it sitting in the garage w/ a disconnected battery and thinking tow it or try to figure it out on my own.
Old Oct 30, 2015 | 10:08 PM
aklim's Avatar
aklim
I would think that for a few hundred you can have a decent scanner that does OBD1 and get some data. I do. Even if you buy a Snap On that is used (The Brick, for example) you can also get a lot of good information.
Like I said, even if I miracled it to your shop, how can you trust that they would diagnose it honestly? For all you know, the plug wires were wrongly placed. Did you watch and document everything that was done or did you leave it there and pick it up when done? I find the latter gives me bad results usually.
Usually, unless I know the mechanic personally, I have it diagnosed, tell the service advisor what needs to be done and the time required, he does the formality of an estimate and the tech I select does the work.
Old Oct 30, 2015 | 11:38 PM
Pa'svette's Avatar
Pa'svette
I know that the idle is controlled by the ECM form several sensors but the OP mentioned the a/c and it reminded me that I had a similar problem when the a/c pressure sensor on my pick up went bad. Thought maybe his got unplugged when they changed the spark plugs.
Sorry if I sent him off in the wrong direction.
To Timing issue??
Old Oct 31, 2015 | 12:24 AM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
A lot less than a few hundred will get you a fantastic scan tool. I have this one. It does data stream, runs diagnostic tests on systems, snap shots...and tons more. Thing is awesome.
OTC Monitor 2000
Old Oct 31, 2015 | 01:40 AM
Joe C's Avatar
Joe C
OTC Monitor 2000
does that thing do both OBD1 and OBD2?
Old Oct 31, 2015 | 10:25 AM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Nope.
