AN fitting for fuel filter
Old Oct 22, 2015 | 08:51 PM
silvvette's Avatar
silvvette
Default AN fitting for fuel filter
Anyone know the AN fitting size, degree angle (I thing it's 37 degree) and tread type for the stock 94 fuel filter:
http://www.partstrain.com/store/details/Chevrolet/Corvette/AC_Delco/Fuel_Filter/1994/ACGF652.html?source=gglpla&c_dev=m&c_aid =43252013546&c_net=g&c2cid=bb5e7bff-1283-47dd-803e-f1a61bf35fae
Old Oct 22, 2015 | 09:05 PM
antfarmer2's Avatar
antfarmer2
Thread Size: M 16X1,5; found this not sure if it helps
Old Oct 22, 2015 | 09:12 PM
aDigitalPhantom's Avatar
aDigitalPhantom
It is. A Russell 648060 will adapter it to -6 AN.
Old Oct 22, 2015 | 09:53 PM
silvvette's Avatar
silvvette
Thank you for that. So we can use the -6 AN side of the Russell fitting to go inside the filter (I'm not looking to use the o-ring side of the fitting) with the 37 degree flare and wouldn't have any leak issues?
Old Oct 22, 2015 | 11:28 PM
aDigitalPhantom
No you cant. The fuel filter is 16mmx1.5 oring you will need a different from factory filter or that adapter.
PS
I should know that is the adapter I'm using to go from the from the factory fuel lines to -6 AN. It's what I did to plumb the fuel system for my swap.
Old Oct 23, 2015 | 04:33 AM
WVZR-1's Avatar
WVZR-1
http://www.partstrain.com/store/deta...e-f1a61bf35fae
Have you just destroyed one of the "nuts/fitting" that's on the fuel line that threads into the filter? Your "thoughts" are incorrect.
There's multiple methods of repair so it's difficult to just give you a simple, "do this". The nut is M16-1.5 but the preparation of the tubing requires specialty tools, the nut is a compression style and not the typical INV FL. I'd suggest contacting a local that understands. There are sections of tubing sold with the correct sealing preparation with nut.
This is a correctly assembled example that you should be able to duplicate locally:
http://www.summitracing.com/parts/rn...FVcSHwodousEYw
To AN fitting for fuel filter
