No Heat
Old Oct 24, 2015 | 03:34 PM
treythejedi's Avatar
treythejedi
5th Gear
Default No Heat
I have a 89 corvette that i been slowly fixing up and now that winter is coming up i need to my heat but my car only blows cold air. I have no idea where to start
Old Oct 24, 2015 | 05:10 PM
antfarmer2's Avatar
antfarmer2
start by grabbing both hoses going to the heater core and feel for heat not sure if yours has a shut off valve.
Old Oct 25, 2015 | 07:29 AM
HlhnEast's Avatar
HlhnEast
On the RH side of the firewall there are two hoses connected to some metal tubes running towards the front of the engine. In the middle of the tubes there is a valve that is vacuum controlled. Check for movement here as this valve allows heated water to enter your heater core. There are also vacuum operated doors under your dash that divert air flow over your heater core. It is possible that your heater core was leaking and a PO disconnected it by rerouting the rubber hoses from your intake to the water pump. If any of that is missing, thats where I would start.
Old Oct 25, 2015 | 09:16 AM
treythejedi
5th Gear
Pics?
Old Oct 25, 2015 | 10:41 AM
antfarmer2's Avatar
antfarmer2
sorry no pics but if you open your hood look at the pass side fire wall. there should be two rubber hoses going to it. if they are connected together someplace before that heater core has been bypassed.
Old Oct 25, 2015 | 02:32 PM
markKlein's Avatar
markKlein
how hot does your digital gauge say the collant is after warm up?
Old Oct 25, 2015 | 11:41 PM
Cliff Harris's Avatar
Cliff Harris
I don't think '89s have the heater bypass setup. In any case, it only works when the A/C is on MAX (C60 systems) or AUTO (C68 systems). At all other times coolant is flowing through the heater core.
Old Oct 26, 2015 | 04:53 AM
treythejedi
5th Gear
It gets up there I'll post a number later today
Old Oct 27, 2015 | 05:48 AM
HlhnEast's Avatar
HlhnEast
You may be right Cliff. I just assume the pre '92 L98 set ups are the same as my '85. No I dont have any pics but IF you have this valve its mounted to the RH wheel well. The whole set up is about 18" long and has 2 metal tubes with rubber hoses connected to it.
Old Oct 27, 2015 | 12:20 PM
treythejedi
5th Gear
I do have the metal tubes
To No Heat
