Question for the Experts!
Old Aug 26, 2002 | 12:25 AM
qwerty111's Avatar
qwerty111
Default Question for the Experts!
When my head gasket blew on my 1990 L98, I had a real problem with those damn torx head bolts. I wound up chiseling most of them to get them to turn after breaking four torx head sockets. I'm considering replacing the torx with allen head bolts when reinstalling. Is this a good idea or should I stick with the torx?
I know several members have done this job more than once and would like to hear some opinions from the Experts.
Old Aug 26, 2002 | 12:42 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: Question for the Experts! (qwerty111)
When I do my heads I will use new ARP bolts.
Old Aug 26, 2002 | 12:45 AM
scorp508's Avatar
scorp508
I used ARP head bolts for about $75.
Old Aug 26, 2002 | 01:48 AM
sinistervette's Avatar
sinistervette
3 for 3, go with ARP! :D :cheers:
Old Aug 26, 2002 | 06:05 AM
pablocruise's Avatar
pablocruise
so far everyone is responding about head bolts that hold the head down to the block. I think I read the post as referring to the torxhead bolts that hold the intake together and down onto the heads. :confused:
I had to replace a few of those and just used a metric allen headed bolt in a few locations. I guess hex headed fastener is an option, just use a washer under the head so the heads don't dig into the soft aluminum.
Old Aug 26, 2002 | 11:52 PM
qwerty111's Avatar
qwerty111
After reading my post, it is obvious I didn't make it clear that it was the torx intake, etc. that were the problem. We all know that the head bolts aren't torx.
Thanks 89 Paul in Cal for seeing through my oblique phrasing.
Old Aug 27, 2002 | 12:24 AM
tkrussell's Avatar
tkrussell
Torx head bolts are designed to take greater torque before failure of the bolt head socket than allen head bolts-- all else being equal, ie, same grade of bolt. They are a good design used widely in aviation and aerospace applications.
(Read the thread in this forum about stripped socket allen head stainless intake bolts from TPIS)
If the Torx bolt is breaking the torx insert of the socket wrench, either the tool is of poor quality or the bolt is severely seized. The latter is typical of dissimilar metals applications (steel bolts in aluminum heads or blocks) or high heat applications (exhaust bolts anywhere).
Liberal use of penetrating oil (eg, Liquid Wrench) and mild heat to the bolt along with patience, prayer, a light hammer, and strong arm usually will work eventually. Hopefully the aluminum threads will not strip out.
The best prevention is antiseize compound to all steel bolts going into aluminum threads or in high heat spots such as exhaust bolts. Curse the factory for not using enough.
Old Aug 27, 2002 | 02:36 AM
HighHopes85's Avatar
HighHopes85
Default Re: Question for the Experts! (tkrussell)
You have valid points...but in all honesty, a torx head bolt with an English thread is not very common and is needed for the lower intake. The uppers are M8X1.25 which is somewhat more readily available. Try to get a price for one bolt from GM and you will walk away swearing that they gave you the price for a set.
I am using stainless steel allen head fasteners for my runners and stainless hex-head fasteners for my lower. For the intended load, I think that stainless will suffice.
Always use anti-sieze on the threads and make sure the lengths are sufficient. A rule of thumb for thread engagement in aluminum is 2X the major diameter. And I follow that rule after having heli-coiled the threads in my upper ;)
Good luck, -Matt-
Old Aug 29, 2002 | 12:35 AM
qwerty111's Avatar
qwerty111
Thanks to tkrussell and HighHopes85.
That's the input I was looking for. Your points are well taken and I will follow your advice. Appreciate your help!! :cheers:
To Question for the Experts!
