Need Spark Plug Recommendation
So the plugs that I am currently using have worked really well for me. They have never fouled out even with prolonged idling. They also don't appear to be overheating either. The ones I am using are stock spec AC Delco for a 1990 Corvette. They are AC Delco FR5LS.
I just purchased a nitrous kit and I want to run a 100 shot. But I don't want to change plugs every time that I want to use it. So I need a plug that won't foul out on me during normal driving but that also won't detonate or preignite during nitrous use. So can I get a recommendation on what spark plug to use for this?
Thank you very much.
I have been doing some research on many threads and asked questions from NGK and some of my friends. The research totals at about 6 hours or more for this. I have determined that an NGK plug in the heat range of #6 will probably be the best for what I am doing.
I ran NGK BKR6E spark plugs in 2014, and I cannot find any evidence of me saying anything negative about them, other than me over tightening and cracking them and my old spark plug wires causing misfires. I could find no evidence to suggest that they were fouling on their own. I ran these with the same engine set up that I have now, with some slight insignificant differences.
When I contacted NGK, they recommended a heat range of 6, but told me to use some crazy spark plug that was a terrible combo for nitrous use.
The research I have done has shown that a lot of people with 383s and AFR 195 heads are using NGK #6 plugs. Lots of mentions of the TR6 plugs with nitrous, and lots of mentions of BKR6E on a 383.
So I think that a #6 or a #7 is going to be right for me. And with a non-projected tip, given that it will decrease spark plug operating temperature slightly further, I think that a 7 would be the best to start with. I would be able to see if it fouled under colder engine temps and idling/no load conditions. However, I really think that a #6 is going to be perfect.
Not sure at this point what to do, do I get the 6? Can someone say confidently that the 6 will probably be perfect, or do I get the 7 first?
Also, the factory recommended plugs for an 85 from AC Delco have a heat range of 3, I am using a heat range of 5 from AC Delco now (which is hotter on their scale). Stock NGK recommendation is a 5 heat range on NGK's scale.
They say to back off 1 heat range for every 100 hp, I have added about 175 hp over stock, so I should probably be using a NGK 7 heat range now according to that and then with the 100 shot of nitrous I should be running an NGK 8 heat range. That just seems too cold to me. My friend is using a NGK 7 heat range plug on a twin turbo LT1 with an estimated 800 rwhp.
This is the spark plug that I am interested in at the moment. Thanks.
http://www.summitracing.com/parts/ngk-4922/overview/
I would start with stock and hook up a laptop to see how it runs with the current plug. I would also think that you'd get the car working 100% perfectly for a few months before you go sticking more complexity on it, but my point is wasted.
