ASR Problems !
Old Aug 26, 2002 | 12:05 PM
Bob Lapine's Avatar
Bob Lapine
Default ASR Problems !
My "Service ASR Light" has come on ! Has anyone experienced this and if so what needs to be done ? What service is required, checking in my car manual revals nothing. Do I have to take it to a Dealer only to get ripped off ? It seems that my ASR would come on every time I would take a right turn and go over a bump at the same time. Does this indicate a bad sensor on the right rear wheel ? Anyone with clues to help solve these problems would be greatly appreciated.
Thanks in advance... :confused:
Old Sep 6, 2002 | 11:16 PM
stanandsue's Avatar
stanandsue
Default Re: ASR Problems ! (Bob Lapine)
My came on last week, and comes on consistently after driving for a while, but not at start-up. I switch-off ASR when the warning comes on. I took it to a mechanic that I trust, and they said the code led to 4 pages of troubleshooting flowcharts. After 2-3 hrs, they said that it appeared that the control unit was not getting power. I'll pick-up the car tomorrow and find out more, including the size of the bill. Meanwhile, you may want to check your fuses.
Stan '92 Yellow 6-speed roadster
Old Sep 7, 2002 | 09:58 AM
mjfox's Avatar
mjfox
CHECK YOUR BRAKE FLUID LEVEL THERE IS ASWITCH THAT SETS OFF ASR WHEN IT IS LOW
Old Sep 7, 2002 | 11:12 AM
MarkLT1's Avatar
MarkLT1
St. Jude Donor '04
Default Re: ASR Problems ! (mjfox)
Yes, but that switch will also give an ABS code (if both come on at the same time, it is usualy brake fluid/worn brake pads).
One thing to check- make sure the vaccum tube, and power socket are both plugged into the ASR box. I unplugged my power socket to relocate my block water temp sensor, and forgot to plug it back in. My ASR light was coming on, and I couldnt figure it out, and since that plug is up under the ASR box, it wasnt easy to see. Once I plugged the darn thing back in, all was fine.
[Modified by MarkLT1, 10:12 AM 9/7/2002]
Old Sep 15, 2002 | 07:59 PM
stanandsue's Avatar
stanandsue
Default Re: ASR Problems ! (MarkLT1)
When new brake pads were installed last week, that seemed to take care of the "service asr" light as well. Incredible price on the brake pads - 10 times what I expected to pay!
To ASR Problems !
