I've read that some clutches hit too hard for a c4 rearend, but I'm an auto guy so idk what brand. Still it don't look like you left too hard and some light spin or the light chirping helps keep the rearend alive with the initial shock. I don't see much squat either. You'll never know the exact cause, but I'd be real careful to make sure you install the next u-joint correct and don't get one of the needles in the end of the cap. Still it could have been the axle that broke 1st.
I've seen some of your post with parts you've used and you should be running much faster. I'd look at your tune maybe, that launch rpm is kinda high.
I'd also maybe buy some half shaft loops like dragvette has. You'll wanna sand/smooth any rough edges made by the broken parts inside the knuckle, but don't take away excessive material.
IMHO, and from fact, you should be able to pull better 60's on tires like that. I can pull 1.9X's on 255/40/17 Dunlap ZII's.....which are a great 200TW auto-x tire but hook pretty good at the strip too!!
I doubt Atco has bad track prep. PRP is pretty sticky as of late. I wish I had air like that around here. I need to do more drag strip stuff again........
Miniram, 58mm throttle body, AFR 195 Eliminator heads, Hooker 1 3/4" long tube headers, Corsa 2 1/2" true dual exhaust, 10:1 compression, 1.6 roller rockers, MSD 6AL2, TPiS flat tappet cam (224*/224* @ 0.050" 0.528/0.528" total valve lift w/ 1.6 RR, 112* LSA), 3.75:1 rear gears, Nitto NT 555R drag radials 315/35/17, and some other small/supporting mods.
Originally Posted by BOOT77
New u-joint, what brand? Solid or greaseable?
Sucks you broke, hope things go better for yah!
They are Moog U-joints. They were not greaseable unless you removed the caps. It broke because I launched at 6000 RPMs by accident with a clutch dump. I turned off the 2 step before the clutch grabbed by mistake. 2 step was only set at 2500 RPMs. In the video it's a 2500 RPM launch and on the following run is when it broke. Only got one run in. Plus, never raced on a track before.
Also, in case anyone didn't see before or forgot, this is a picture of the dyno run.
[Street tires, you get them real hot they just grease up and can get slipperier
Like they said just skip the box url][/QUOTE] Now that looked like fun. Nice car too.
So, I see with your HP, that getting into the 12s, with 350 horses, is doable. Dang Daniel, bet you get there next season andthat will give you dragging rights with your friends ( and here to seeing as how am trying to get into the 13s). best of luck and know we are rooting/pulling for you.
Well, 12s is not a problem for me. It's trying to squeeze an 11.99 that will be the problem. lol
Doesn't the 108.11 mph trap speed seem kinda low for 344 rwhp?
It does to me. My stock + Muffs C6 trapped 112, here in UT at 4200' elevation. It was a little lighter than your car, and it did put down ~360 RWHP...but still other 340 RWHP 3300lb cars trap better than 108.
You need more complete passes. As I said, go back when fixed, and make passes to start with, not worrying about your RT/ET/60, etc. Just lay down some very clean passes. Then you'll get a legitimate trap BASE that you can work from and scrutinize.
I weighed the car about 2 weeks ago and it was 3360 lbs. with me in it and a full tank of gas...
This is why I asked you about your modifications.
I looked at your dyno sheet as well.
My stock (Setup for SCCA B Street auto-x=NO power mods or driveline, very limited modifications in this class) 93 ZF6 runs consistent 13.4-13.5's at around 102-105. My best was a 13.38@105.
I had my car dyno'ed on a Dynojet and on that day it made 246 RWHP and 304RWTQ. My car is 3300lbs without me in it at least on that scale.
I think given your modifications you picked up quite a bit of HP and only 40ish TQ? That seems not right at all, compared to a stock LT1.
I think 108 is too slow for your HP levels and goals. I agree with Tom that you need to make more passes before making any decisions or conclusions. I have 45 passes to draw data from on my car.
I agree, not enough data yet. You need at least 10 consistent passes before any useful conclusions can be drawn.
