Looking to add some spark. I'm soon going to install a sniper nos system (100 hp, maybe 125) and looking for suggestions on spark. I'd like to stay with MSD. Keeping in mind that this is a carbureted HEI setup what do you guys suggest? This is also a manual trans so want something with rev limiting. Thanks, full setup below.
1986 Corvette, Edelbrock intake, Holly 670 Avenger, roller cam & lifters, Trick Flow aluminum heads, Hooker long tube headers, 6 speed Richmond, Hays flywheel and clutch, aluminum high flow water pump, 4 core aluminum radiator.
MSD 6AL2 Programmable version with and MSD distributor. The programmable version has a timing retard function and you can design a custom timing curve.
