........ Are there any "magic" specs as deviation from factory settings for a car that spends far too much time at the drag strip ? ... Getting ready for an alignment and thought I'd check with the Pro's here first ........
Im really interested in rear camber.
All the negative camber used in road race specs surely is not good for drag race, but im not sure what the best compromise is.
On my 84, I set it up so that there was zero camber with the suspension bottomed out on the snubber (which was extended so that the half shafts were level).
Mine had about 2* positive camber at ride height but with the different camber curves of the early and late suspension designs using the ride height measures that won't work for everyone.
Will
