adjustable front shocks.....
Old Nov 8, 2015 | 05:28 PM
ricky's c4's Avatar
ricky's c4
Default adjustable front shocks.....
what is everyone using for adjustable front shocks .....want street shock with dragstrip settings......95 c4.....
Old Nov 8, 2015 | 05:59 PM
93Rubie's Avatar
93Rubie
The shock you want is a QA1. It fits your application perfectly.
Old Nov 8, 2015 | 07:04 PM
BOOT77's Avatar
BOOT77
If they made coilover fronts for the older cars that's what I'd use for drag.
Old Nov 9, 2015 | 10:24 AM
ricky's c4's Avatar
ricky's c4
can you give me the correct part number for them....thanx......
Old Nov 9, 2015 | 12:20 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Why?
Old Nov 9, 2015 | 12:41 PM
BOOT77's Avatar
BOOT77
More travel if needed from what I've read. Easier to adjust ride height, well on other cars front coilovers idk bout the c4 ones cause I don't have any.
Old Nov 9, 2015 | 01:06 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Huh. I think the C4's travel is limited by the shock, and bump stop.
Coil overs would give you easy ride height adjustment...that is true.
Old Nov 9, 2015 | 01:20 PM
BOOT77's Avatar
BOOT77
Can always get a longer shock with coil over or even springs. I put longer shocks on my front and think the mono spring hits when at full travel, not sure if a coilover would go much further but it may.
edit: I mean the mono spring seems to be limiting the travel.
Old Nov 9, 2015 | 05:09 PM
ricky's c4's Avatar
ricky's c4
I bought Viking shocks....all 4 adjustable.....660.00...i'll let you know how I like them shortly......
Old Nov 9, 2015 | 06:05 PM
rklessdriver's Avatar
rklessdriver
Viking shocks pn B207.
It's what I run on the front of my 84 race car.
Will
Old Nov 9, 2015 | 06:10 PM
BOOT77's Avatar
BOOT77
Nice were did you get them from? I am planning to get some rears this winter.
Old Nov 10, 2015 | 04:35 PM
ricky's c4's Avatar
ricky's c4
e-bay....all 4 for 660......look like a nice shock ....we will see.....
Old Nov 11, 2015 | 10:15 AM
Rodney@ridetech's Avatar
0Rodney@ridetech
Former Vendor
Rick, we offer a Single Adjustable shock for the C4's. It is our Smooth Body line, which is a Monotube design. It would allow you to set the shocks for the Strip then change the settings for the drive home. The Monotube is quicker reacting than a Twintube shock due to the fact your are moving the Piston through the oil rather than the oil through the shock. We do a 1,000,001 mile warranty on them, but they are a rebuildable, revalvable shock. Different tracks may take a different setting and that's were the Adjustable shocks come in handy. Do like we do on our cars, keep a small notebook in the car to write down your settings for the track and the street. Whenever you go to the track, get your notebook out and return the car to the settings you had in it last time. You will have the ability to fine tune them to your needs. A click one way or the other can make all the difference when fine tuning the setup for the track or street. I attached a link to them on our site.
http://www.ridetech.com/store/muscle...ures_hash=V363
Rodney
Old Nov 12, 2015 | 07:21 PM
ricky's c4's Avatar
ricky's c4
Rodney
this is good info, just a little late for me.... I ordered shocks a couple days ago...just got them today...I would of considered these if I knew about them......look like a great shock....
Old Nov 12, 2015 | 08:29 PM
RichS's Avatar
RichS
I use QA1. I used a single adjustable for a while but recently went to a double adjustable on the front. Very happy with them over the years.
Old Nov 15, 2015 | 12:23 PM
ricky's c4's Avatar
ricky's c4
shocks worked great....still maybe more tuning...only made 3 passes...car hooked harder with better weight transfer....I did remove the front swaybar also....I'm sure that helped a little...a lot more rise in the front and holds it there longer....
Old May 5, 2020 | 06:50 PM
Nicholas Passarelli's Avatar
Nicholas Passarelli
So I have a question regarding shocks, I recently lowered my corvette and was wondering do the ride adjustable shocks with the internal bypass raise and lower the car I want to lift the car ever so slightly and I know shocks will lift it because they are new mine is original with 60k on them but if I set the shock rate higher or lower what does that do to the profile of the shock. would it be worthwhile to put coil overs upfront for added adjustability? If I hit a hard bump my tire contacts the top side of my fender well
thanks for the help
Nicholas
Old May 5, 2020 | 09:14 PM
Kevova's Avatar
Kevova
You should have started new thread vs resurrecting the dead. Shock absorbers dampen the action of the spring. Other than coil overs and air bags, shocks are not intended to support vehicle. Adjusting rear spring bolts will raise front slightly as rear end rises.
To adjustable front shocks.....
