I have an odd request
Old Nov 15, 2015 | 05:52 AM
ANTI VENOM's Avatar
ANTI VENOM
Default I have an odd request
I moved my engine accessories to the passenger side of my car. Unfortunately my strategy didn't work out perfectly. My power steering slips the belt. I would like to ask if someone could measure how much belt contact there is on your pulley from where the belt starts to touch the pulley to where it leaves the pulley. This way I have a base line or a goal rather. TIA
Old Nov 15, 2015 | 06:00 AM
project C4's Avatar
project C4
what are you using for belt tension ?
Old Nov 15, 2015 | 06:54 AM
WW7's Avatar
WW7
I just went out in my cold azz garage and measured where the belt makes contact with the pulley...The distance is right at ( 7") which is less then halfway around the pulley...It's also the rear of the belt that rides on the pulley not the grooved side .My car is an 89 ......WW
Old Nov 15, 2015 | 07:07 AM
ANTI VENOM's Avatar
ANTI VENOM
Factory tensioner in non-factory location
Thank you. I appreciate your sacrifices. On my factory belt position sticker, it only appears to be about 30% wrap. That is a guess from memory. I guess I need closer to 7".
Old Nov 15, 2015 | 09:27 AM
project C4's Avatar
project C4
it helps to have the spring tensioner in the correct part of its travel also.
Old Nov 15, 2015 | 10:15 AM
ex-x-fire's Avatar
ex-x-fire
A picture of the set up can help too.
Old Nov 16, 2015 | 12:54 AM
ANTI VENOM's Avatar
ANTI VENOM
Can't get a good angle on it.
Not exact, but hopefully you will get the point.
Old Nov 16, 2015 | 07:00 AM
ex-x-fire's Avatar
ex-x-fire
Maybe add a pulley or two between the a/c & p/s pulleys.
Old Nov 16, 2015 | 07:23 AM
ANTI VENOM's Avatar
ANTI VENOM
I envisioned something like that. Pretty slick. I'll have to broaden my search and see what sizes are out there. I was thinking about hitting my local wrecking yard for ideas also. It was actually a little harder to get everything to fit than I thought. Plus it is difficult to hold things and measure and consider the tensioner movement. If I have to pull it all out again I'll tweek things just a bit. The belt coming off of the PS pulley is pretty close to the belt coming off the idler. The water pump is right in there as well. Thanks for the pic.
Old Nov 16, 2015 | 01:08 PM
project C4's Avatar
project C4
does the p/s pulley have grooves ? looks like you are running the smooth side of the belt on a grooved pulley. I may be looking at the picture wrong. i do see groove marks on the flat side of the belt though.
Old Nov 16, 2015 | 09:20 PM
ANTI VENOM's Avatar
ANTI VENOM
You are looking at it right, but those grooves are just that, grooves. They are not deep enough nor are they intended for the "ribs" of the belt. That is my factory pulley and as you can see from the belt diagram on the shroud, the PS pump is driven in a reverse direction and by the back of the belt. I hope that is right. LOL, This project has gone a little longer than expected and my memory isn't great.
Old Nov 16, 2015 | 10:37 PM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
Hah! that looks like mickey mouse with an ear infection LOL LOL LOL
Old Nov 21, 2015 | 12:35 PM
Bluezman's Avatar
Bluezman
I can't tell for sure, but it looks like your configuration is causing the power steering pump to run backward. I don't even know if that matters or not but if it is backward and it can't work in that direction under load, maybe that's contributing to the belt issue????
Old Nov 21, 2015 | 05:54 PM
WW7's Avatar
WW7
Look again, the belt is turning the pully counterclockwise, the same as it was before the conversion...WW
To I have an odd request
