Okay how do I tighten a bolt
I can tighten all the upper and middle bolts, just not the bottom ones. Those are ever so slightly harder to get a perfect perpendicular angle on with the wrench without hitting the cylinder head or something else in the engine bay. I'm doing this replacement the hard way, without pulling the engine. Without being able to get the bottom bolts yet on the 70 ft/lb pass, that means I can't get far at all with the way the sequence of tightening them goes.
So with different combinations of wobble / not wobble extensions of various lengths I've tried to get as straight and angle as possible on those bolt heads and the sockets just slip right off at around 40 ft/lbs. Recommendations?
Edit: Pictures are below
[ EDIT ] I assumed the engine in question is an L98. Apparently that is not the case... [ /EDIT ]
Last edited by Cliff Harris; Nov 27, 2015 at 01:08 AM. Reason: My assumption appears to be wrong.
Edit: Yep ARP runs smaller
You shouldn't be able to "round out" a correctly sized 6 point socket on a hex head bolt, break it (yes) but "round out" seems very unlikely (very). I would expect the 1/2" hex Joe mentioned if they're 6 point hex. 13mm socket is for sure a poor choice I'd think.
i'd be willing to bet the OP is using 12 point sockets on 6-point bolts. this combo works OK in most cases, but when you throw in the slightly larger, 13mm thing, not getting a straight shot on the bolt, and IMO, 70 ft.lbs is asking for trouble.
I asked part # of bolts and brand of sockets, very inexpensive sockets have a substantial recess to the actual tooling. A less than centered socket to hex of bolt will slip every time. He mentions difficulty accessing in his original post also.
Well is the torque wrench calibrated? I had a Hobo Fake Tq Wch lose cal and shear off 1/4-20 bolt heads. Really best TW for holding a cal is the beam wrench.
Finally it reads like u need a very strong but thin wall socket. U will have to shop around for that or maybe ARP has a specialty tool for this (they want to sell u of course). I recall 65ft-lbs is a lot of torque and takes plenty of grunt to get it there w/o a cheater bar.
Are you sure your torque wrench is correct and your not over torqueing them?
edit: Are you sure you do not have counterfeit bolts? They make a lot of fake stuff these days.
Im thinkn now the smaller bolt head (1/2" verses 5/8") should allow more clearance for a thicker socket. A new impact socket should be tight - but maybe not now that the bolt head has rounded. Maybe only fix is to buy new "short" bolts and use a fresh impact socket.Sorry for the loss in parts here.
This is what I'm thinking.
Now they're damaged in the same way as my other sockets - little chunks taken out to the right side of each interior corner.
Why won't my 1/2" sockets seat well enough on these bolts to stay on them while I turn? Why do they slip off when I hit about 40 ft/lb?
I checked my torque wrench against another one, and I seriously doubt I'm strong enough to exceed the required 70 ft/lb by that much. So it seems to just be a combination of a bad initial angle on the bolts (as I try to pry down diagonally from my seated position on the wheel) plus a little damage to the bolt that's also encouraging slipping. Why such minor damage encourages the 6-point sockets to slip to such a major degree is a mystery.
Is there any trick to holding the torque wrench better? Maybe I'm just not good at turning it in a plane exactly perpendicular to the bolt. I'm grabbing the wrench at the far end and twisting in approximately that plane, but I can tell the amount of force makes the wrench and socket want to **** a different direction. I'm using my other hand on the head of the torque wrench to try to stabilize it from cocking more, but yeah right, there's just too much force at play for that assistance to really work. It just ***** until it slips off.
the torqueing process itself - sounds like you're doing it right - using the palm of your left hand and apply slight pressure on the head of the torque wrench, and directly down on the fastener. the little extra insurance the socket is firmly seated squarely on the fastener, and using only the handle of the t-wrench, and applying a smooth, rotating action.
finally - shop vac the hell out of that thing to get all those little metal pieces that I'm seeing in the pic!
one more thing - you are using a properly sized torque wrench for the job, and no kind of torque amplifier or anything? it might sound like an odd question, but I just have to ask. just puzzled and thinking outside the box.
i'm not sure how thread sealant on the threads would affect torque values, but i'm thinking assembly lube under the washer shouldn't. any kind of lubricant on the thread could cause, up to a 20% error in torque values. any error, whether caused by lube or sealant, I wouldn't think would contribute to the kind of bolt damage we're seeing here.
one more question to the OP - the ID of the washers are beveled on one side - are the washers oriented correctly to the bolt head? the beveled side of the washer to the underside of the bolt flange - IMPORTANT! just trying to think outside the box.
