Delamination C4
Old Nov 26, 2015 | 06:58 PM
jseremba's Avatar
jseremba
Default Delamination C4
Hello Everybody,
I owna 1989 Z51 witha manual transmission. The hood is delaminating. I have some ideas on how to fix it. But, I was hopng to get my ideas validated by you all.
So how do I fix it . Thank you
Old Nov 26, 2015 | 07:05 PM
c4cruiser's Avatar
c4cruiser
It would be a big help if you would post some pics of the problem. area.
And you may also want to post your question in the Paint/Body section of the forum. There are some very knowledgeable body guys in that section.
Old Nov 26, 2015 | 07:14 PM
jseremba's Avatar
jseremba
How do I post a picture.
The delamination is occuring on the driver side. The hood as it comes down to form the fender is delaminated.
There is a body group. I will check. Thank you
Old Nov 27, 2015 | 10:15 AM
Kevova's Avatar
Kevova
Clear coat delamination is a strip and repaint deal. Because how a C4 is constructed all effected parts need to have all original paint removed then prepped and paint per paint supplier. Delamination is cause by poor adhesion between color and clear paints, it started during the mid 80s - early 90s with OEM paint. It generally effects top surfaces more than sides and lower edges.
Old Nov 27, 2015 | 10:27 AM
jseremba's Avatar
jseremba
I am not talking about the paint and clear. The plastic is separating.
Old Nov 27, 2015 | 10:30 AM
Phillip123's Avatar
Phillip123
Take it to the high pressure car wash and blast the clear off (And clean it at the same time)
Old Nov 27, 2015 | 10:46 AM
FASTAZU's Avatar
FASTAZU
2018 C4 of Year Finalist
2015 C4 of the Year Finalist
St. Jude Donor '16
Could have been repaired at some time, maybe they used a non-compatible component of just a bad repair.
Old Nov 27, 2015 | 12:37 PM
antfarmer2's Avatar
antfarmer2
To Delamination C4
