I recently picked up my "new" 92 aqua metallic conv in Louisiana. The water pump went the first day back in Massachusetts. New water pump and vent modification to the Opti and i'm back in business. Now the many little "fun" repairs. The previous owner, working on the door trim, sparked/shorted, with a screw driver, the driver's side electric door lock. Now neither side works. The first thing I found that looks like it's worth looking at is 30 amp power door lock fuse, in auxiliary fuse block 1. The owners amnual says this is on the passenger side up over the "knee bolster". I've looked in my service manual and can find no info on how to get to this. Any suggestion or info would be greatly appreciated
Open the pass/door. At the end of the dash you will see a panel housing the pass fuse panel. I think the door locks are fuse no. # 42. 20 amp. I think its what your looking for?
The fuse block Lou is describing is the main fuse block. The 30amp breaker labeled PWR ACCY leads to both the powerseat switchs and a 15 amp fuse in the auxiliary fuse block #1. If your power seat still works then the 30 amp breaker in the main block is ok. If this is the case, then you will have to find the 15amp fuse labeled PWR DOOR in auxiliary fuse block #1. It is located behind the passenger knee bolster. Get one of this http://forums.corvetteforum.com/zerothread?id=370170 :cheers:
From: No more yankee my wankee, the Donger is tired!
Re: Auxiliary fuse block (Ramrod92)
Well since nobody has really given you a great description....
Remove the hus panel, it has a few bolts and some screws. You have to remove a few from the main fuse box area to remove it.Get a flashlight and crawl underneath the kick panel on the passenger side. Works best if you lay on your back on the door sill area and cram your head where your feet should be. Look in the back of the well up on top towards the center of the well. You'll see another small fuse block that holds 5 fuses. Pull them one at a time until you find it
