Why would it have a code 36?
Anway, when I got back in the car after work and fired it up everything seemed fine until for just a second it acted really stupid, the RPM's fell and it bucked like crazy, did this twice, then it drove just fine all the way home.
I got home and fixed the O2 sensor and fired it up again. I still got an SES light. Code 22, cool no problem. I adjusted the TPS a little and made that go away. I then took it for a spin. I probably drove for 45 miles or so, took at least an hour. Everything ran perfectly, no troubles with anything.
When I got home I washed the car. When I went to start it up it cranked longer than usual and immediately threw a code 36, which is related to the Opti, low resolution pulse.
Now I didn't open the hood when I washed the car, I assure you it didn't get wet. So what's going on here? This opti has less than 1000 miles on it and has not been wet.
If this thing is toast already it re-enforces my belief that the older style was actually superior. It had 76k miles on it, weighed enough to be full of oil, and had been greatly abused and ran perfectly. This new and improved one craps out already? What a waste of time and money. I suppose I'll drive it to work today and see if I can actually make it there.
I drove it to work today and it still had the code.
It actually threw this code as soon as it started up, and it had to crank longer than usual. It had been firing within half a revolution, since it has set this code it has to turn over several times before it fires.
Otherwise it runs great. Is it possible that just one of the wires going to the opti is damaged somehow? I'd really like that possibility more than having to replace the stupid thing.
Nice try though :cheers: I'd love for it to be something so simple.
Just looked it up - 94 went back to MAF. I was only of by two years!
[Modified by Steel Blue 91, 11:53 AM 8/28/2002]
Also,clear the codes after repair attempts.
Hope its something simple...good luck and keep us posted.
If it is vented, blow some air through the lines. I did this and the problem disappeared (for a while!).
My guess is that you should start saving up for a new opti. These things never get all the way better, they just tease you by running nice for a little while.
Maybe, just maybe this is what will happen. I attached the vacuum line but if there was any crud or anything in it, it hadn't cleared because I hadn't run it. Thus when I fired it up this morning it still set the code. Possibly after driving it to work the vent sucked whatever the crap may have been in there out. Perhaps when I go back out in an hour and 12 minutes it won't throw the code.
If not I'll certainly try to blow it out. Do you mean by mouth or via airhose, I have access to both.
Good luck
[Modified by ittlfly, 2:20 PM 8/28/2002]
I was headed down the parkway with the cruise set on 70 when it just decided for a few seconds to screw with me. It felt like a misfire on just about every cylinder for a revolution. I know it was more than just a simple misfire because every time it would do it my tach would fall suddenly and then come back. I don't mean fall just a little either, all the way to 0. It missed a little, missed again. I shifted into 5th, and hit the gas, it did it again once or twice and then quit. I put it back in 6th and cruised on home. It never did it again and it never set a code.
Sound like the opti?
I know it's somewhere in the ignition system because of what the tach does.
This is getting real old real fast, I don't exactly have the money to replace a piece of junk distributor that has less than a thousand miles on it and has never been wet.
When the idle got bad enough, I blew it out with a can of air (for cleaning key boards and such). Instantly smoothed the idle.
As a matter of fact, I had both vaccum line plugged into each other for a while.
Contact Sam Smith at Fairway Chevy. 1-800-395-1440
(SamSmith@fairwaychevy.com)
Here's what I got:
non vented opti #10457702 $270.00 complete unit.
Shipping LasVegas to CA, $4.50.
If you've got more time than money, you could try just cleaning the opti. The terminals were corroded on mine (only 7-8K miles). But plan on a complete replacement in the not too distant future.
[Modified by John Row, 5:33 PM 8/28/2002]
Now I just have to track down another set of water pump gaskets.
:smash: :smash:
I think I could probably change just the opti in an afternoon.
Keep us posted when the car is done...heck if I ever got an LT1 car,youd probably become my opti mechanic...lol...Id hate to deal with thoise things.
It's intermitten right now so I'm still going to hop on the dyno this weekend.
