1985 Idle Issues Code 54
Old Dec 9, 2015 | 12:16 PM
Hobbitrabbit's Avatar
Hobbitrabbit
Default 1985 Idle Issues Code 54
Hey guys. I just got done installing a new fuel pump and starter and I'm getting a code 54.
Some background on the car- I rebuilt the engine and after driving fine for about 3 months, there were some serious issues with stalling out. So I parked the car, cleaned the TB, verified the EGR to be functional (It holds vacuum and actuates freely) cleaned the intake plenum, replaced the fuel pump, and bypassed the anti-theft in case that was acting up. I am getting spark and fuel.
Right now the car will start, although it has to turn over many, many times before it will fire up. It will then idle steadily for about 5-10 seconds, before it starts surging extremely dramatically, almost loping like it's got a massive cam. Eventually, it dies altogether. If I give it gas, it stays alive. Injector resistance test is within spec (16 exactly) so I'm not worried about that. Noid light also confirms functionality.
Also throwing a Code 54, low fuel pump voltage. I know the fuel pump is fine, it's new.
I'm thinking it may be the relay for the fuel pump, or I may need to set Idle Air and TPS voltage. Or both. Recommendations?
Thanks so much!
Old Dec 9, 2015 | 12:38 PM
antfarmer2's Avatar
antfarmer2
pull the vacumme line of your fpr and smell for fuel could be the relay or the pump or just a bad connection.
put a fuel pressure gauge on it while running and see what it does.
Old Dec 9, 2015 | 12:41 PM
Hobbitrabbit
Just to be clear is an FPR my fuel pressure regulator? I'm not familiar with that acronym or the location of said part on the car.
EDIT: just looked it up. Vacuum line definitely smells of fuel. Assuming this means the FPR is compromised?
Old Dec 9, 2015 | 12:45 PM
antfarmer2's Avatar
antfarmer2
yes I believe it is on the pass side rear top and round with 6 safety torque screws on it
Old Dec 9, 2015 | 01:12 PM
Hobbitrabbit
Sweet. Its definitely smelling like fuel. What's causing this? How does a bad FPR cause that problem? Fuel pressure not getting high enough maybe?
Old Dec 9, 2015 | 01:19 PM
brushmor's Avatar
brushmor
The regulator has a diaphragm inside that probably has a leak letting fuel into the vacuum side.
Old Dec 9, 2015 | 02:47 PM
antfarmer2's Avatar
antfarmer2
you will need the right bit to open it up. they had a bad run on them make sure the button is smooth and polished like the old one.
Old Dec 9, 2015 | 09:27 PM
aklim's Avatar
aklim
cleaned the TB,
Thanks so much!
Have you really verified that the Code 54 is justified? Just because you have a new fuel pump doesn't mean you have good power to it, does it? I can't remember how to make it work but supposedly 85 is an odd year for scanners? If you can, get a scanner to see if the voltage really dips low. Better yet if it can datalog for a while so you can clear the code and see what the voltage is when it reappears.
Hope you removed the IAC, IAC housing and cleaned the passages too.
Anti-theft has nothing to do with this. If you put a piece of tape over the pellet, you can turn the key and I can't remember but it either won't crank or it will cut off the injector pulse. I believe it won't crank but that was so long ago I did that.
Did you get a blue flame? Did you check the wires for voltage leaks?
Resistance is meaningless at best, misleading at worst. It doesn't tell you whether there is something obstructing the fuel flow to the pintle. Only bench testing tells you that.
I don't know if the idle was set right but that is another story for a later date.
Old Dec 9, 2015 | 09:28 PM
aklim's Avatar
aklim
I suppose if the fuel gets into the intake, it can cause issues but I would still check the scanner to see if the pump voltage is wrong. If it is, check with a DVOM at the terminals of the pump.
Old Dec 10, 2015 | 02:44 AM
Cliff Harris's Avatar
Cliff Harris
The fuel pump voltage has to be less than 2 volts to set error code 54. Basically it means no voltage is going to the pump from the fuel pump relay. Based on your description of your starting problems, it appears that the oil pressure switch is taking over and running the fuel pump.
Old Dec 10, 2015 | 08:26 AM
antfarmer2's Avatar
antfarmer2
Old Dec 10, 2015 | 09:34 AM
aklim's Avatar
aklim
And the way to test that is? Disconnect the oil pressure switch and see what happens? Since it is a redundant power supply, we could cut the feed and see whether the pump gets the power. However if it is a redundant power supply, would it not give steady power and not affect his running?
Old Dec 11, 2015 | 12:35 AM
Cliff Harris
The oil pressure switch is a backup for the fuel pump relay.
If the fuel pump relay is bad (as we suspect from the symptoms), then disconnecting the oil pressure switch will mean the pump will never run.
Old Dec 11, 2015 | 01:03 AM
aklim's Avatar
aklim
I was thinking that the switch being removed would tell us if the entire pump wasn't working. Mauby run straight wire to the pump?
Old Dec 11, 2015 | 04:01 AM
xrav22's Avatar
xrav22
My loping was cured by a new 02 sensor along with idle adjust, also clean and apply clear dielectric grease to all connectors that go along with the code. Actually every connector in the engine bay probably needs care.
Old Dec 11, 2015 | 07:49 AM
antfarmer2's Avatar
antfarmer2
good job
To 1985 Idle Issues Code 54
