Cooling Fan
What year is the car? Early C4's have a single fan behind the radiator (there may be a optional small fan in front of the A/C condensor. LAter C4's will have two fans behind the radiator. Also, C4's can have different temperature rated thermostats that will determine what the normal coolant temperature is.
There are sensors on the engine that send signals to the ECM to operate the cooling fans. As mentioned, there are high and low coolant temp values that the ECM uses to turn fans on and off.
When you turn the A/C on, the ECM turns the engine fan(s) on. With the engine at normal operating temp (lets say at around 195 degrees) is the main fan running? If not, turn the A/C on. Does the fan run?
Even so, that analog gauge your looking at does not even have a linear scale. So, it is next to impossible to tell what the actual temp being displayed really is.
Unless the needle is actually into the "shaded" area at the upper end of the scale, your temp is not too hot.
Push the "Gauge" button and cycle through all of the options displayed.
One of them is engine coolant temp. Displayed next to the fuel gauge below the speedometer.
The temp displayed there will be more accurate, but it will still be hotter at idle than your probably used too.
Normal when moving at any speed above 25mph = 190°F - 200°F
Normal in stop n go traffic or at idle = 200°F - 235°F
The temp will rise and fall as the cooling fans kick on and off.
At highway speed the temp should remain constant.
So, there is no way you could tell if the temp reading was 200 or 250.
3/4 on the display is pretty normal.
And yes, the fans will come on with the A/C off.
But they won't come on until the temp reaches the "fan-on" program settings for your year car.
Not sure for the '95, but it will be approx. 228°F (when looking at the digital display)
At that temp, your analog gauge needle will be very close to the upper end toward that shaded area.
But the needle should not actually make it into the shaded area.
That analog gauge is just about useless really, as all it does is scare the crap out of people.
If your temps really do get too hot, you will also get a "check gauges" light display.
With the proper coolant mix and pressure, your coolant does not boil until approx. 265°F
While the digital display does provide good data, the coolant temp is probable the most important display especially if you think you may have some sort of problem. But from the temp values you posted, your cooling system is fine.
