Sending unit
Old Dec 22, 2015 | 08:04 PM
jose7740's Avatar
jose7740
Default Sending unit
I just ordered the 1985 sending unit for my 1984 Vette, there should be no problems with compatibility, right? I want to take advantage of more powerful pump of the 85 unit compared to the 84 one.
Old Dec 22, 2015 | 10:39 PM
jv9999's Avatar
jv9999
Not a good idea. The '85 pump has about 2.5X the pressure.
Old Dec 23, 2015 | 12:19 AM
jose7740's Avatar
jose7740
According to CF senior member Hot Rod Roy, there is no problem because the regulator will handle the new pump.
Old Dec 23, 2015 | 12:52 AM
corvetteronw's Avatar
corvetteronw
Cruise-In VII Veteran
Cruise-In VIII
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
Read this:https://www.corvetteforum.com/forums...re-engine.html
Old Dec 23, 2015 | 02:00 AM
Hot Rod Roy's Avatar
Hot Rod Roy
If you compare the fuel pumped by an '84 pump, with the fuel pumped by an '85 pump, with the fuel flowing into a bucket, the fuel pressure will be the same for both pumps . . . zero! The pressure is a function of the pressure regulator, not the pump. The '85 pump has a higher capacity, and the use of an '85 pump in the '84 is a very popular modification.
A garden hose is the same idea. There's no pressure in the hose until you put your thumb over the end of the hose!
Here's a thread with some other discussion on the subject:
corvetteforum.com/forums/c4-tech-performance/3751977-fuel-pump.html
Old Dec 23, 2015 | 10:51 PM
jv9999's Avatar
jv9999
If there was no pressure, no water would flow. Also, there is no regulator in most garden hoses.
Old Dec 24, 2015 | 11:40 PM
jose7740's Avatar
jose7740
As soon as I get that new unit, I will post how does it works
Old Jan 2, 2016 | 07:02 PM
jose7740's Avatar
jose7740
Today I installed the new pump/sending unit on my 84, the car started right away, no leaks, accelerates good on the lift, I will not be able to road test it until I finish the brakes, right now it looks like I will need new front steel lines since the nuts on the brake hoses do not want to come out and I already damaged the nuts, hopefully I can find them, will let you know how the car runs with the new pump/ sending unit as soon as put it back on the road
Old Jan 5, 2016 | 08:55 PM
jkann1's Avatar
jkann1
Default Rough Idle on start up
Hi, I just bought a 84 c4.. I don't know anything about the crossfire injection.. it has 2 flaps on the air breather they are open before I start it and when I start it I think one closes the other stays open it a rough idle until it warm up ... after warm up it runs smooth.. is that normal .. I know it shouldn't idle rough what kind of problem am I looking at... or any suggestion I really thank you for your time...
Old Jan 5, 2016 | 11:40 PM
jose7740's Avatar
jose7740
Both flaps are open when the engine is cold, when you start the engine they are supposed to close and open gradually until hot, check for he vacuum hose under the air cleaner to make sure a hose is not broken.
Old Jan 5, 2016 | 11:48 PM
jkann1's Avatar
jkann1
Thanks.. I will check them out
To Sending unit
