fitting size for low pressure power steering
Old Dec 23, 2015 | 06:15 PM
vstol's Avatar
vstol
Default fitting size for low pressure power steering
What size is the thread for the low pressure power steering hose into the gear box? Thanks
Old Dec 23, 2015 | 06:18 PM
WVZR-1's Avatar
WVZR-1
M16 - Saginaw I'm quite sure but I believe I can confirm easily. Return towards reservoir correct?
I thought I had a rack here to actually confirm but I can't put my hands on it. What did you use for the pressure side of the rack? If you used M18 there it's M16 on return
Old Dec 26, 2015 | 01:08 PM
vstol's Avatar
vstol
I found it, it was 6mm thanks
Old Dec 26, 2015 | 05:36 PM
WVZR-1's Avatar
WVZR-1
6mm I hope was a typo and it's actually 16mm and Saginaw with the sealing ring.
Old Jan 17, 2016 | 04:39 PM
vstol's Avatar
vstol
typo it is M16 and I assume the high pressure is M18 in the rack with M16 going into the pump
Old Jan 17, 2016 | 05:36 PM
WVZR-1's Avatar
WVZR-1
yep!!
Old Jan 17, 2016 | 05:52 PM
vstol's Avatar
vstol
thanks
To fitting size for low pressure power steering
