Strange Interior Lighting and Sound when the Key is on
Intl Council of Corvettes
Hello Folks,
I am in need of a recommeded solution for the strange issue I am having with my 85 vette. It started about a month or so ago and for the life of me I can't seem to find out what is causing this. When I turn the key to the ACC or run position and turn on the headlights or parking lights, I get this rapid ding, ding, ding while the lights are on....It stops when I turn the lights off. Also I noticed when I first get in it, start the car, and put it in gear the interior lights stays on for about the same amount of time then they go off. I pulled the delay module to see if this had anything to do with it and I still get the same symptoms. I am ordering another headlight switch and delay module anyway but wonder if this will fix the issue. I searched the forum and saw a few posts that suggested door jam switches or even the the headlight switch but was not sure. Don't realy want to replace switches just for heck of it but I am stumped on this one.
just gently pull out the door switches and gently close the door to ajust.
Thanks for responding. Are you referring to the ones at the rear of each door? I did notice the one on the driver door is sticking a bit.
I will update this post once I get a chance this weekend. I went ahead and ordered a new headlight switch and delay module to have on standby anyway since these items have already proven to go faulty over the years.
Hello all. I just wanted to give an update since I have had a chance to troubleshoot this. I tried lubing this switch and work it gently in and out but still got the same result. I even too it out and did a continuity test on it and it seems to work fine. When pushed in as it would if the door is closed, I got an open on the multimeter. when I pulled the plunger out just slightly I go a short indicating contact inside. I will to bet this is the front jam switch instead. I then sprayed the front switch with the front switch but did notice some sticking. I went ahead ordered a set from Corvette Central. I also swamped out the headlight switch with a new unit just to narrow it down. Once the front jam switches come in I will install and provide another update.
Hello Folks,
Look for it in the fuse box.
I had checked the fuses as wel but none were blown. I went ahead and disconnected the Audio Alarm Module and no more sound. I still have the ignition switch to install and soon as I get a chance I plan t replace.
