1985 L98 WOT Lean out
got a mostly stock 1985 L98 with the 4+3. It starts and runs absolutely fine hot an cold. No bogging, no hesitation, backfires, whatsoever. Fuel system, all sensors etc. are tuned up. IAC and TPS are new and adjusted the right way. The injectors and chip are the original ones.
The car sees some drag racing now and then. I use a ZEX wet nitrous system with a 125 hp shot and Hoosiers on track days. For nitrous usage initial timing is retarded 6 degrees as stated by ZEX.
The only problem I have: The car runs very good ( low 13´s with a best of 13.16 in the quarter mile on spray ), but leans out immediately after shifting into third. The mixture won´t fatten up at the 3 to fourth shift.
This happens with and without nitrous usage.
I´m located in Germany ( still no speed limits at our Bavarian Autobahn ). The car accelerates very good, even in third, but leans out while accelerating. After accelerating, the Vette feels like throwing an ancor at 134 mph. I feel the car would go into high 12´s with a fatter 3 and 4th gear mixture.
Question is: Is it injector time? They ohm out nice at 12,6 all 8. But does that keep them from shortening at revs beyond 3800 rpm? I feel I should do the fuel pressure at driving test by taping the gauge to the windscreen to make sure the new Walbro 255 is ok. To compensate for the problem I raised fuel pressure to 50 psi, it looks a bit better, but that´s not the right way.
What you think? How can I know that new injectors would be the right move?
AFR is measured with a wide band O2 sensor mounted directly beyond the original O2 sensor at the driver side exhaust. I can read what´s happening with that little gauge.
Racetech gauge
Bye Erik
email Jon at fuel injection connection. look to the right for their add. good deals.
Ohm test tells that the coils are OK. Doesn't tell fuel volume or spray. Get the things tested ever few years. Never ran an Ohm test on any of my injectors. All it does it give you a FALSE sense of security that all is well because the test came out good.
If you are running that kind of power, why not just change the injectors for better and larger ones and set the tune. This way, you can set the car to run WITHOUT the bottle and it runs perfect. Maybe get something from Moates which can allow you to run 1 tune for NA and one tune for nitrous?
What i forgot to mention is the strange acting new TPS.
We´ve done the IAC setting, than the TPS was adjusted to 0.54 V at idle. Idle is perfect now.
But when i go to WOT I only get a 3,87 V readout. Is it possible I have a bad new TPS, so the power enrichment isn´t engaged by the ECM due the lack of voltage? Or is 3.87 V enough to get the PE started?
Bye ! Erik
Bye ! Erik
You said that your car leans out in 3rd and also feels like and anchor was thrown out at 134 mph. I'm not sure you can go 134 mph in 3rd or if these things are relevant.
No sorry, it starts to lean out in third, but keeps accelerating. You shift into 4th and it keeps acceleraring....until 134 mph. At this point it feels
like you were stepping heaviley on the brakes.
Snowy roads these days in southern Germany, so I have to wait for the fuel pressure test until the local Autobahn is clear of snow and ice. I´ll keep you informed what is going on further
But related to this situation, I asume that something is going south today. Maybe it is the MAF slowly dying now ( bothrelais were changed last summer ).
My plan is the fuel pressure while driving check to make sure the new fuel pump an filter are doing fine. I will screw in new injectors in the same stock size, so the electronic tune in stock form should work fine. Should the problem persist, I will try to get a MAF from a german buddy, to test and make sure, that´s not the problem. Next step would be to go into the tune on the chip.
I need a scanner and are asking myself what would be the best equipment for real time scanning with later extensions for burning a chip. The Ostrich stuff sounds hot to me.
First I need snowless dry roads
-If you get a scanner not the MAF readings when the car starts to lean out.
The racetech display is mounted in the cockpit, so I can read it while driving. At idle, in 1st and 2nd gear the LED it at the max power point ( see pic ), even if I am at 5000 rpm. In 3rd it is falling immediately in the red zone, till no light is shown. Not good for the L98 and not good for the time slip.
Is it possible,that the injectors are going into lock up because of high rpm and 50 psi fuel pressure? But then again why are they working fine in first and second gear? This again leads my thoughts to the MAF.
Bye !
Bye !
This seems like a strange situation, and like I mentioned before you need to check fuel pressure before anything else.
The car has no idea what gear you are in the tune is not adjusted by the gear you are in. I have a theory but it may not be the issue, please check the fuel pressure first.
Is it possible that you have a miss on one of the cylinders when you get to a longer pull (longer pulls create more demand on the ignition system) like third and 4th gear. If you have a miss the WB sensor will show lean because there is excessive air in the exhaust due to the miss. I have seen spark plug gaps that are too large or weak ignition systems do this. what is your spark plug gap? I would set it at .025 for nitrous use and N/A use and see if the problem goes away.
Our US Army trucks were limited to 100 KPH and we were very jealous when guys like you and the bikers would fly past us back in the 80s.
https://www.corvetteforum.com/forums...-when-hot.html
But you US-Army boys ever had the best US-Cars around in Germany. I remember hanging out in Stuttgart at the Rock Fabrik. Many soldiers were there.
Same goes for Munich back in the day. I bought my other car from a lady at the US-Army in Munich, as she went back to the States she left the car, which was my luck back in ´88. Know what.....the Trans Am is still mine 32 years later
The old T.A.
Wife in the Vette
Bye !
