Fitting Coil-overs
next problem, the 10" spring is too long. with the coilover adjusters all the way down the chassis heights are 6" in the front (or 27" eye-brow height)
it was 5 & 5/8" with the z51 spring in.
Probably should have gone with a 9" x 550 lb spring.
The installed height of the 10" 600lb spring is 8"
spoke to guru jim, he says bring the springs in and he will try and 'scragg' them down an inch.
thats cool I dont mind jacking it up and taking everything apart again !
Show us pictures of yours when done !
http://www.autospeed.com/cms/article...rings&A=112276
honing out the bushing with a master cylinder hone in a drill,
and using a 30 mm piece of bar with paint on it, to size it up,
bolted back on with some fresh Energy Suspension grease and it rotates but is still tight.
It might make a lot more sense to order another pair of springs that had an inch or two shorter free length with a similar coil spacing to what you have now. After all, the beauty of coilovers is the ease of spring changes.
I did a test fit with the 450 lb spring and the coil over assembly just about fell in !
I cant believe how much easier the 450 lb spring is to fit in.
Those bloody 600 lb springs have caused me so much grief, but at least I have done the hard work to get them in and I can sway between them when I need.
Great work and Thanks for the pictures.
dropped the car down on its wheels, its at 26 1/4" eyebrow height, and just a fraction over 5" at the chassis jack-up points. It can still go lower but there is 2" compression travel left on the shock so I will give it a trial run at that height and check against the rubber o ring on the shaft to see how much the shock is moving on the road.
it effectively doubles the cost (and value) of converted american cars.
but for some reason there is a heap of left hand drive DeLorean's that are registered in south australia ?
Jim
Jim
the bolt on the end of the sway bar is 7/16" so I chose that size for the rodends.
I used a 7/16 male right hand thread and a 7/16 female right hand thread.
the washers are 7/16 hardened, and the bolts are 7/16 high tensile zinc coated.
you guys in the states are lucky, you can find this stuff everywhere cheap with free shipping, or just go to the local fastener place that sells this type of stuff, and get chromemoly or stainless.
if you look at rsc337's thread he has the later model suspension arms so you can see they are slightly different, but you can just bolt the rodends straight to the arm (unlike the early arms where you need to fab a bracket to do this)
he moved his sway bar forward, or you can do what i did and grind the back of it for clearance as the rodends give you a bit more clearance as well.
