bad backfire no start
Old Dec 30, 2015 | 06:49 PM
94VenomVette's Avatar
94VenomVette
Default bad backfire no start
Whats up guys got a quick question for this stubborn problem.
Installed my LTCC kit and finally found my white EST wire. I have it all wired up grounds nice and tight and clean. New opti installed as well GEN1 optispark spline drive, which went in fairly easy. Coil harness is also hooked up properly as well. Tried to start the car and its backfiring badly through the intake and the engine seems to be holding like when the distributor is 180* off. I got a green light when cranking so Im puzzled here. Any ideas where to start from here?
Old Dec 30, 2015 | 08:22 PM
antfarmer2's Avatar
antfarmer2
did the spline go in easy or did you force it in?
Old Dec 30, 2015 | 08:36 PM
94VenomVette
after playing to line it up it went in easy and is flush
Old Dec 30, 2015 | 08:45 PM
antfarmer2's Avatar
antfarmer2
look at you wireing might have swaped some check and check again. all plug wires click twice.
Old Dec 30, 2015 | 09:24 PM
94VenomVette
nah i went over all of it. All wiring is done, coils have power, opti is signaling and getting fuel and spark. I bought a summit opti bc my other opti took a dump on the high res side. Im thinking its something internal to the opti at this point. it spits out the intake as if its firing on the intake stroke. I matched all the wiring on the coil harness to each cylinder, ex 1,3,5,7 are Purple, Blue, Green, Red and 2,4,6,8 Red, Green, Blue, Purple.
Old Dec 30, 2015 | 09:55 PM
THE 383 admiral's Avatar
THE 383 admiral
Sorry, about the luck. You should have left the OE Opti. Since you do not need the High side.
is the Summit Opti. Known good?? Never Create more Work. Unless it's NEEDED.
Hopefully. you get this resolved soon. the LTCC kit is a great upgrade. And makes a big improvement.
I actually reduced. Some timing in my tune. The OE table is very high 44deg in areas.
Old Dec 31, 2015 | 07:31 AM
94VenomVette
i didnt know u didnt need the high side, but i think the other opti was a summit as well, and dont trust it im sure the low side wouldve eventually bitten the dust. Im going to check a few things today and if all else fails ill exchange the opti for another. I also want to delete the MAF and go strictly VE table. ill see what happens
Old Dec 31, 2015 | 07:56 AM
TorchTarga94's Avatar
TorchTarga94
It looks like your coil harness wiring is correct. I goofed up on the odd bank wiring and had it backwards on my first start. Found that out quickly. I would verify again just to be sure. Double check to make sure cylinder bank harnesses coming from the LTCC module is going to the correct bank.
I am sure you have these pinouts, but just for reference:
The best thing I can tell you is to retrace your wiring one more time, you will find something you missed or skipped. Verify the two pinks and the whites are soldered to the appropriate factory wires.
Patrick
Old Dec 31, 2015 | 09:53 AM
94VenomVette
thanks, im going to go over it again this afternoon. the LTCC harness 1357 goes to the driver side and 2468 passenger side. Checked my White EST and pink wires and there all good. whats funny is when i reversed the harness and put 1357 on passenger side car started up but wasnt firing right but stayed running. BTW how did you hook up your tachometer? Im going to check everything from scratch today, ill even pull the opti and reinstall it just to verify, cant hurt.
Old Dec 31, 2015 | 10:36 AM
LT1_383's Avatar
LT1_383
I think what TorchTarga94 meant by reversed is that the 1357 harness might be hooked up 7531; in other words, can you flip the harness front to back? Learned that from the school of hard knocks myself.
Old Dec 31, 2015 | 10:40 AM
antfarmer2's Avatar
antfarmer2
I would put some red locktight on the cap screws.
Old Dec 31, 2015 | 10:47 AM
94VenomVette
so you think the LTCC Harness maybe backwards? so even though my driver side is hooked up with the LTCC plug 1357, and my coil harness matches 1357, your thinking its wired wrong so i should flip my harness on my coils? so Instead of it being Purple, Blue, Green, Red I should reverse it so 1357 go Red, Green, Blue, Purple right? I can reverse it that no problem.
Old Dec 31, 2015 | 11:17 AM
TorchTarga94
For a 1994 and maybe 92/93 you have to bypass the tach filter. It is a little black box (maybe an inch long) and has two white wires feeding into it. Cut the two wires and solder them together. Boom, your tach will work. On a 95/96 you don't have to go through this because there is no tach filter as the PCM feeds the tach signal.
Where are your three grounds connected? LTCC Module, and both coil harnesses?
Old Dec 31, 2015 | 11:33 AM
TorchTarga94
This is what I thought at first because this is exactly what I did the first go around. The odd bank and even bank are "reversed" so to speak. However, according to post #5 he is hooked up correctly. Hard to confirm that though without being there in person.
So, now that we can assume your coil harness wiring is correct, lets confirm your spark plug wiring.
Odd Bank
cylinder 1 is towards the front of the car and number 7 is toward the back.
Even Bank
cylinder 2 is towards the front of the car and Cylinder 8 is toward the back.
This would lead you to think that the even bank is exactly the same as the odd bank when it comes to the coil wiring. However it is completely opposite (which it looks like you know).
I.E. - Cylinder 2 utilizes the red wire, so this would lead one to think Cylinder 1 on the opposite side also uses the red wire, where in actuality, it utilizes the reciprocate wire (purple). And so on....
Simple Table:
Wire Color---->Corresponding Cylinder
RED------------>2 & 7
GREEN---------->4 & 5
BLUE------------>6 & 3
PURPLE--------->1 & 8
Old Dec 31, 2015 | 11:43 AM
94VenomVette
my grounds are in this fashion. The Coils have 10AWG looped to each other, paint cleaned off coils and connected and ends in the front on cylinder heads. The 1357,2468 ground is hooked to the stud on the coils as well. the LTCC Box is grounded with 10AWG to the back where the EGR Valve is bolted on, again ground tight and clean. I Dont think grounds are an issue here to be honest. Firing order is correct on coils to plugs, so i can rule that out. It seems to me either something in the harness is wrong, IE wired wrong from build by Bob, which i dont think is the case OR the opti i put in the disc is reading wrong which could be a possibility. What i found wierd was the car started when i connected the LTCC 1357 plug to passenger side and vice versa on the other. but sounded like it was on 4 cylinders and running like crap, i tried to blip the throttle and it backfired like a 12gauge shotgun out the tailpipe.
Old Dec 31, 2015 | 11:54 AM
TorchTarga94
Yes, this is looking like the culprit, but the fact you got it to run briefly (albeit horribly), by switching the harnesses tells me something is goofed in your setup. Because mine did the same thing, felt like it was running on four cylinders, I just had the odd bank hooked up backwards.
For $hits, connect the coil harness grounds to the fuel rail hold down bolts. Don't put both grounds on the same bolt, utilize a bolt on each side. Not sure where your LTCC module is fastened down but it should be grounded to iron if possible.
Old Dec 31, 2015 | 11:55 AM
TorchTarga94
BTW- good luck, you are almost there.
To bad backfire no start
Old Dec 31, 2015 | 12:15 PM
94VenomVette
yea the LTCC is iron grounded, where the egr valve bolts to the back of the intake. I'll report back later this evening if i made any progress. Does the Water temp sender have to be hooked up bc i have it off for now. i dont think it does though
Old Dec 31, 2015 | 12:22 PM
TorchTarga94
Yes the water pump sensor has to be hooked up!
Old Dec 31, 2015 | 02:14 PM
94VenomVette
Ok lol i didnt have that hooked up didnt think that would affect starting
