ECM code 45
Old Aug 29, 2002 | 08:24 PM
csapow's Avatar
csapow
Default ECM code 45
'91, L98, 106k miles, auto. The ECM has set a code of 45 (rich exhaust indicated). Does anyone know what is the most probably cause?
Thanks in advance
David
Old Aug 30, 2002 | 09:45 PM
csapow's Avatar
csapow
Default Re: ECM code 45 (csapow)
ttt
Old Aug 31, 2002 | 01:08 AM
GRX's Avatar
GRX
I would start with checking the TPS (throttle position sensor) voltage.
A GM manual is necessary.
Old Sep 1, 2002 | 03:38 AM
88_vette's Avatar
88_vette
Default Re: ECM code 45 (DOCTOR J)
First place to start would be with a scan tool and check your 02 sensor volts. There a few things that have to happy at at the same time for this code to set. Also check for exhaust leaks. This can trick the 02 sensor and give false readings which lead to codes.
To ECM code 45
