I have an 86 pace car and just rebuilt the engine and got everything up and running again. The only issue I am having at this point is the timing. I did the steps that the FSM says to do and still around 1200 in Park and 79 in drive.
When I set the timing at 0 with the timing connector unplugged everything is perfect all the way around. It is sitting at 72-78rpm in Park and 64 in drive. As soon as I plug the wire back in and crank it, it jumps right back up. I also disconnected the battery to clear codes.
Just put a new computer and prom in it also. Am I missing something? Why does it change as soon as that timing plug gets plugged back in...
Because the ECM takes over the timing adjustment and sets it to 20°.
That's why you disconnect the EST connector -- to prevent the ECM from changing the timing. What you are doing is setting the base or mechanical timing -- the relationship between the distributor and crankshaft.
So you're saying that I need to set it lower to compensate for the computer bumping it up 20 degrees? I not quite sure I understand...
I cranked it cold this morning and the idle was great, right around 750 and then once it reached around 120 degrees it jumped up to 1200.
Thoughts? I'm so close to have this damn thing running right again....
It's sounds like under 120* is where you're problem is. Cold starts need to have high idles. Set the timing to 6* instead of 0*. The ECM retards timing by 5* when the engine is cold, probably why it's idling low when cold and higher when warm.
Since you have your engine rebuild and freshly mounted into your engine bay,you need to set the timing at 6 degrees mechanical ,as said above.That said, you need to adjust the base idle as x factory specs at .54 V at TPS sensor on the throttle .there is a procedure to do this,serch the FSM.only when your TPS is adjusted at .54 v and timing is set at 6 degrees you can evaluate your idling.
