92 corvette remote starter night mare!
Old Jan 11, 2016 | 11:59 PM
Brianbajnauth's Avatar
Brianbajnauth
8th Gear
Default 92 corvette remote starter night mare!
I have a 92 corvette manual
I'm installing a viper 5704v on it. I have the door locks hooked up and functional. Now to the remote starter part... When the remote starter is hooked up and I press the button to start the car the ignition and acc all come on but it does not crank! I press back the button on the key fob and it shuts the system down. ... Now I try to start it with the key and it doesn't do anything. All the ignition and acc come on but it just doesn't crank. After 5 mins or so I am able to crank it only with they key!
I also have a custom prom chip tuned with vats turned off
Any ideas? Thanks in advance
Old Jan 12, 2016 | 02:12 AM
WVZR-1's Avatar
WVZR-1
I interpreted "manual" to be an M6
An M6 requires the clutch pedal to be depressed to allow starter engagement. That can be defeated to allow crank BUT CERTAINLY NOT TO BE DONE FOR REMOTE START - IF YOUR A$$ ISN'T IN THE SEAT YOU DO NOT WANT THE CAR TO BE CAPABLE OF CRANKING
I'd go so far as to say that if you didn't realize this maybe, just maybe you shouldn't even ask any further questions regarding it.
There's one more obvious component that contributes to your 5 minute error but I'll not explain.
Old Jan 12, 2016 | 07:27 AM
Brianbajnauth
8th Gear
Thank you for the respond
I forgot to say that I have jumped the two wires at the clutch switch
So the car starts without having to press the clutch.
What other way would cause it not to start every 5 mins after using the viper?
Old Jan 12, 2016 | 07:53 AM
antfarmer2's Avatar
antfarmer2
did you bypass the vats system? you can use a ohm meter on the key to get the right resistor off ebay or el shop.
sorry about the cranky member must have missed his nap.
Old Jan 12, 2016 | 07:55 AM
WVZR-1's Avatar
WVZR-1
You did - you say do the FE in the tune/PROM but I'm guessing that you haven't done the VATS "key resistance" bypass.
You realize how damn dangerous that is? REMOTE on an MT WOW
Old Jan 12, 2016 | 08:18 AM
Brianbajnauth
8th Gear
I had the vats tuned out from the prom chip
Brianbajnauth
8th Gear
Don't fully understand? Fe in prom? I'm sorry lol
Old Jan 12, 2016 | 08:20 AM
Brianbajnauth
8th Gear
I had the tuner disable vats from the ecu
Do I still need to put a resistor in?
Old Jan 12, 2016 | 08:22 AM
antfarmer2's Avatar
antfarmer2
I have never done it but believe you need to do the key bypass too. many threads on this.
Old Jan 12, 2016 | 08:31 AM
Brianbajnauth
8th Gear
Iv found threads but everyone does just the key no one that tuned it out
Old Jan 12, 2016 | 08:36 AM
antfarmer2's Avatar
antfarmer2
that does not seem to be working I would spend the 25 cents and try the resistor.
WVZR-1's Avatar
WVZR-1
FE Fuel Enable and yes to the you need to accomodate or bypass both aspects of the VATS to accomplish crank/run.
I didn't mention it where I stated obvious in my first post because I though it was saving you from yourself. OH WELL -
Now you know the "rest of the required". It is though silly, foolish and reckless maybe on your part to even consider it.
Old Jan 12, 2016 | 08:46 AM
Brianbajnauth
8th Gear
Where would the starter enable relay be loaches and how do I bypass it?
Brianbajnauth
8th Gear
Located*
Old Jan 12, 2016 | 09:16 AM
antfarmer2's Avatar
antfarmer2
you disconnect the wires under the dash by the steering column and jump the resistor there.
To 92 corvette remote starter night mare!
