1987 C4, Momentary SES light, 7 trouble codes??
So fast forward to today, I take the car out for a drive and no SES light, no problems. So I stop into a different O'Reillys and get someone who at least appears to know what he's doing. He pulls 7 codes in this order:
51: PROM- Memory fault
44: Lean Exhaust
41: Cylinder Select Error
63: ?
61: ?
54: Fuel Pump Circuit voltage low
52: Oil Temp sensor low
Could a vehicle possibly have 7 error codes and drive totally fine without SES? Could there be a single global issue causing this many codes? Or are all these codes erroneous? I am concerned, and REALLY don't want to take it to the dealership.
Pull the codes yourself:
https://www.corvetteforum.com/forums...post1574918379
http://corvettephotographs.com/c4vettes/codes.htm
What they mean (use this chart, as others are not year specific and result in bad diagnosis):
https://www.corvetteforum.com/forums...post1576116036
See if it comes back.
Note when undoing the battery cables multiple times be carefull to not strip or overtighten your connectors. However I hear there is a wire you can unplug and plug back to do the same thing but I have never been able to do it that way with success.
Good luck on the right track
Code 32 is caused by this switch either not closing when it should or being closed when no EGR is requested. Hope this helps and happy hunting.
