adjust brake switch
Old Jan 30, 2016 | 12:30 AM
xrav22's Avatar
xrav22
Default adjust brake switch
Hi all I have fitted a new brake power booster and now my brake lights are on all the time. I have read to pull out the end and it will ratchet and also to turn it until it is the right length. I don't want to mess with it too much so which way is it. It is about 3 mm off. It is a 1985
Thx
Old Jan 30, 2016 | 03:05 AM
WVZR-1's Avatar
WVZR-1
Thx
You should be able to "push" towards the pedal and the plunger in the switch will turn off the lamps. It requires very little effort.
Actually I believe the FSM will suggest depressing the pedal, pushing the switch until it's fully seated against the clip/retainer and then pulling the brake pedal towards you to adjust.
Name:  Stop light switch.png
Old Jan 30, 2016 | 10:43 AM
xrav22's Avatar
xrav22
Thanks I I will try it.
Old Jan 30, 2016 | 07:28 PM
xrav22's Avatar
xrav22
Didn't realize how easy it was thanks for the tips. My brakes also work better now with a new booster.
It also came with the valve which was to my surprise.
http://www.oreillyauto.com/site/c/de...1305&ppt=C0066
if anyone is interested.
To adjust brake switch
