Passenger side power window issue
Old Jan 30, 2016 | 07:12 PM
plawrencejr's Avatar
plawrencejr
8th Gear
Default Passenger side power window issue
I have a 1996 Corvette and the passenger window does not go up or down but the driver side is fine.. I went through the diagnosis steps from the manual. It looks like the Blue wire has power but the Brown does not. I replaced the switch and the fuse no luck. Does any one have any idea what could be the issue?
Old Jan 30, 2016 | 07:15 PM
antfarmer2's Avatar
antfarmer2
does it work from the drivers side?
Old Jan 30, 2016 | 07:25 PM
plawrencejr
8th Gear
No it does not
Old Jan 30, 2016 | 07:36 PM
antfarmer2's Avatar
antfarmer2
not sure maybe a bad connection on the drivers side.
Old Jan 31, 2016 | 06:39 AM
kenmohr's Avatar
kenmohr
Had trouble with mine also. A friend said the wires break where they go into the door. Wasn't my problem however. The connector behind the radio had a burned pin. spliced it and all is fine. Check those two areas. Door first it is easier. Ohm meter from dash to inside door. Good luck
To Passenger side power window issue
