Are the lower control arms on the front of my base 85 corvette and an 85z51 interchangeable?
I want to purchase both sides to replace the bushings and ball joint prior to removing mine and I found a set of Z51 control arms. I don't plan on changing anything else at the moment.
The front control arms are interchangeable on the early C4s. Some are marked Z51 but the difference is in the bushing durometer (stiffness) not in the hard part.
