expensive lesson
Old Aug 31, 2002 | 09:29 PM
brookman's Avatar
brookman
Default expensive lesson
I just bought my 88. I disassembled my digital dash gauge cluster because of how filthy it was and I needed to replace a lamp socket. The cleaning went fine and during disassembly I noticed a weird S shaped clip near the top of the center display. Well... not wanting to leave out any thing important I put it back when I re-assembled it. It slid down a little - un noticed by me and when I tightened the assembly back together it shattered the top of the center display. Now the volts and coolant temp don't work.
Hopefully this will help someone else from making the same mistake.
On the same note. Any one have a Digital Dash Gauge cluster for sale?
:mad
Old Aug 31, 2002 | 09:41 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: expensive lesson (brookman)
Ouch, tough break.
You might try Contemporary Corvette (link on my site) or another Vette bone yard (maybe even C&V, local to you). Maybe you can get a digi display that doesn't work but has the LCD in tact on the cheap.
Old Aug 31, 2002 | 10:06 PM
SSLT1KID's Avatar
SSLT1KID
Default Re: expensive lesson (65Z01)
or check ebay
Old Aug 31, 2002 | 11:27 PM
69mako's Avatar
69mako
Default Re: expensive lesson (SSLT1KID)
:cry
Old Sep 1, 2002 | 10:32 AM
red-y's Avatar
red-y
Sounds like something I would do.. :bb
Old Sep 2, 2002 | 12:39 AM
ZAD54's Avatar
ZAD54
You might want to check this guy. http://www.gordonkillebrew.com/ He was the tech guru at the Vette plant for all the C4's and he has a near photographic memory. He should be able to tell you where to get it fixed cheap or find a new one. I talked to him this morning at the Museum and he said a friend of his just bought a business fixing them so it might be worth a try. :seeya
Old Sep 2, 2002 | 10:51 AM
Jay Axson's Avatar
Jay Axson
:cry :cry Sorry to hear that.
Old Sep 2, 2002 | 11:07 AM
RocketSled's Avatar
RocketSled
I did something very similar on reassembling my dash. Found a junkyard owner on the vette net that had a replacement lcd assembly for $50.
Look around, I'll bet you'll find something similar. It's certainly cheaper than the $300 they want for a 'rebuildable' dash. (If one of the LCD's is cracked, is it considered rebuildable?!?!)
Old Sep 2, 2002 | 11:17 AM
JonM's Avatar
JonM
Try these people..I have never used them, maybe you can get a part.
http://www.corvettedashclusterservice.com/
To expensive lesson
