L98 Plumbing Questions
Old Feb 9, 2016 | 10:40 PM
mt01's Avatar
mt01
Default L98 Plumbing Questions
I'm getting ready to install a new engine in my '86 and have some plumbing questions.
#1 - Is it really necessary to run coolant through the oil filter adapter, or can I eliminate this? I live in a hot climate.
#2 - Same question about the throttle body. Any downside to deleting the coolant lines that run through it?
#3 - What's the best way to deal with the stupid clamp that holds the EGR tube to the manifold? I'm thinking of grinding the "ears" off of the old clamp to make it round, then putting a hose clamp around it.
Thanks!
Old Feb 9, 2016 | 11:09 PM
antfarmer2's Avatar
antfarmer2
No need for heat deleat.
Old Feb 10, 2016 | 01:18 AM
Cliff Harris's Avatar
Cliff Harris
That's an oil COOLER. You decide if you need it or not.
Many people have bypassed the throttle body coolant (heater) lines with no ill effects reported.
Do a Google Images search for "EGR clamp" for some ideas:
http://images.google.com
Old Feb 10, 2016 | 01:30 PM
flashstang's Avatar
flashstang
4th Gear
The throttle heat stops icing of the throttle body in cold weather. The oil cooler is just that. Gordon
To L98 Plumbing Questions
