Harmonic balancer test
Old Feb 13, 2016 | 05:14 PM
mlm0's Avatar
mlm0
Default Harmonic balancer test
I'm still chasing down a miss at idle. Without going through the whole list of things I have done, I can assure you I have done all the normal things and adjustments
I am down to egr issue, balancer issue, or internal leaking valve. Is there a way to determine if my balancer has slipped so that my timing adjustment is not correct. I have read several messages on this forum that this fixed the very same idle miss I have
1989 stock L98 with auto trans, 50,000 miles
Old Feb 13, 2016 | 06:45 PM
ex-x-fire's Avatar
ex-x-fire
Turn your engine over till the mark lines up on the timing tab large V notch, pop off the dist cap. The rotor should be pointed at #1 or 180 out.
Old Feb 13, 2016 | 08:25 PM
BOOT77's Avatar
BOOT77
I use a marked damper cover to check, but they cost about the same as a new damper. Is the rubber all cracked?
Old Feb 13, 2016 | 08:52 PM
mlm0's Avatar
mlm0
Originally Posted by ex-x-fire
Turn your engine over till the mark lines up on the timing tab large V notch, pop off the dist cap. The rotor should be point to #1 or 180 out.
Thanks, I'll give that a try, but how accurate is that, or will it be close enough?
Old Feb 13, 2016 | 08:54 PM
mlm0's Avatar
mlm0
Have not looked that close yet. Is it just the outer part of the balancer that slips. I guess the complete balancer can't slip because its keyed?
Old Feb 13, 2016 | 08:58 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
That isn't very accurate, and if it's slipped, not accurate at all. You wouldn't know if the timing (distributor) was off (since you have a problem) or if the DAMPER had slipped.
Make a "J" shaped piston stop out of a coat hangar. Stick it in #1 cyl, bring piston up till hits. Mark damper. Turn backward until it hits again, mark damper again. TDC is dead center between your marks. Is that where you OEM mark is?
Old Feb 13, 2016 | 09:13 PM
ex-x-fire's Avatar
ex-x-fire
The ones that I've seen that have slipped were like 50 or more degrees out. Finding tdc through the spark plug hole on a sbc is a pain.
Another way to check it is to remove the crank pulley, line up the mark to the v notch & feel or look if the crank key is at the 1:30 position.
Old Feb 14, 2016 | 01:57 AM
Cliff Harris's Avatar
Cliff Harris
You can check your harmonic balancer by lining up a straightedge with the side of one of the spokes:
It's advanced from the groove by a slight amount. I don't remember the exact number, but it's something like 6°.
To Harmonic balancer test
