Something about parasitic lost
Here what i've get from nultimeter, shoul be considered ok? Not so practical with that scale
Here is the way to test your parasitic drain:
1. Close car doors and disable or remove your under-hood lights.
2. Disconnect your negative battery cable.
3. Put a short jumper wire between the negative battery post and the negative cable.
4. Connect your multimeter IN PARALLEL with the jumper wire, connecting to the battery post and the battery cable.
5. Wait until the interior lights go off.
6. Remove the jumper wire without disturbing the connections of your multimeter.
7. Your residual current drain should be less that 50 mA (0.050 A)
(The residual current drain of my '84 is about 12 mA.)
EDIT: Just noticed, your red test lead is in the 10 A location. I don't know what your meter will do with this, but the 10 A plug would only be used if the
10 A switch position is selected. You should be using the standard center connection of your meter for the red test lead. Notice the mA label on the center plug. That's a nice multimeter.
Be aware that the fuses for multimeter amp readings are special low resistance fuses. They usually cost at least $5. Check the manual for the meter for more information, like part numbers, etc.
As Roy noticed u must have blown the fuse. The amp meter reading is a direct short accross the batt and that has plenty enough current to weld with. If u keep measuring accross the batt terminals u will keep blowing the fuse.
If u what to test the batt u need a "load tester" like this: http://www.harborfreight.com/100-amp...ter-61747.html
My problem is that this season i'm not using every day car and she stays stopped two-three weeks after a long ride when I come back to the car battery voltage is 11,9V. Car start immediately any troubles, just i think 11,9 is not a good value
FYI, most but not ALL meters have two fuses one for the low amps like you did to test and another for the 10A selection. That one is likely fine and the setting to be used for the testing you did.
If you ever happen to buy a Fluke meter, I have a 88 model, those fuses are like $15 each!!! You learn not to blow those really quick. Mine I got at an auction with both blown and I've only put in that one set. I don't want to pay for them again! I got the meter for $150 new they are $500 or so.
0.03 mA would be 0.00003 A. We appreciate your attempts to help, but please be more careful about your responses.
I'm defending my ideas with facts, not personal attacks! (cardo0, do you recognize that motto?)
And yes wrong polarity is a great indication your not connected correctly or your reading is incorrect/meter on wrong quantity or malfunctioning.
...And for those folks that insist that the red lead be connected to positive, I say that the electrons don't care what color the wire insulation is.
You can use the 10A max banana jack when the meter is set to the 10A scale. Also note that above the 10A jack it states "unfused 10 sec max off for 15 min". This meter is a disaster in the makings. I suspect the shunt resistor in the meter (probably something about 10milliohms) will become your fuse, except it won't blow. It will probably melt and smoke as resistors do.
I suspect you didn't measure anything with the meter configured as in the picture. Like other people have said, that is measuring 30 microamps which is relatively nothing. That might be the meter noise. Pull the leads off. Does it read the same or close?
Be safe with that meter and save up for a good Fluke meter. Don't use that to measure any significant voltages or currents. I would not rely on it to keep yourself safe! :-)
