when the ignition is on, everything works as it should, but when motor starts .... interior fan stops working ... it can be a sensor?
it is a Corvette C4 1986 mod.
If your '86 has C68 AUTO AC I believe the blower actually runs for a brief period when "keyed on or run". I believe it's dependent upon inside/outside temps sensed by the system.
If the car has manual AC C60 I don't believe it's possible.
after fan has stopped, when I start the engine, the key being out for about 15 minutes before I get fan to start again .. could it be? blower control module ? can i test the module? ohm ??
The blower control module is all electronic so it can't be tested with simple tests.
The BCM is controlled by the HVAC controller so there are more electronics there. Again, no simple tests possible.
You're pretty much limited to wiggling wires...
I've measured that it is about 10V of HVAC in bruun line at BMC in 4 wire connector, so it should be ok HVAC. has ordered a new BMC so I hope it will be good.
