Molding Strips painted.
edit: just noticed from your avatar, your car is black. just how bad does it look painted? I know it's not right, but living with it as is, may be the best route here -
This was a refinish by a "chain refinishing vendor" or privately owned collision/refinish center?
You've not mentioned near enough information other than to explain that "replacement" is the only fix. You'll demolish likely all of the moldings attempting the removal and if it was done in "the same operation" as the car color you have very serious issues. Very serious issues.
The interesting part of this is.....How did that get lost in the shuffle?? Normally on a complete paint job, the estimate will have what work is being completed and the cost associated with each part of it....I would guess, you just agreed to a new "spray paint", no real body work (because if they did a quality body work/spray) that belt line would have come off and they would quickly realize that this material may not hold/wear paint like the fiberglass body.
hmmm.. interesting.....but the good news is.....the car is black anyway by looking at your avatar like mentioned......not as much harm, I guess.
If it was done in "car-color" I'd maybe question the entire job. I don't believe that an early C4 can be painted without removing the moldings. PERIOD - a quality refinish requires it - there's no short cuts.
If the shop knew what they were doing and used an adhesion promotor on the moldings well maybe ....
Did you get what you paid for? You've yet to mention the money spent.
