'92 Dealer installed Keyless Entry-Programming
Old Feb 21, 2016 | 11:14 AM
helphos's Avatar
helphos
Default '92 Dealer installed Keyless Entry-Programming
I have a 92 coupe with a dealer installed keyless entry system. I only have one key-fob, so I bought another one at the auction site. It came with no directions, and the directions I googled didnt work (hold the lock switch down, then cycle the key off-on-off-on-off, etc.
Does anyone here have a similar system and/or directions to program the remote? The part number on the fob is GM P/N 12495653.
The current key-fob works great, opens/locks the doors, opens the hatch. I also have a '93 vert with the PKE system, which used to work great until I broke a tiny tab in the fob changing the battery. That's what made me want to have an extra fob for my '92.
If anyone has a 'dealer installation guide' or similar documentation on the dealer installed keyless system for '92 or earlier, I'd appreciate it!
Thanks, and Save the Wave!!
Old Feb 21, 2016 | 12:18 PM
don hall's Avatar
don hall
May help (?): http://www.keylessride.com/default.asp
Old Feb 21, 2016 | 05:48 PM
helphos's Avatar
helphos
Originally Posted by seabright
Oh, well! I went to that site and put in my information, and they couldn't help me. I think it's because my remote was dealer installed, and not from the factory.
But thanks for pitching in to help!!
Old Feb 22, 2016 | 11:10 AM
WVZR-1's Avatar
WVZR-1
Depending on the production date of the kit used there would be different transmitters. The earlier kit used a 12332776 transmitter and is generally considered '85 - '91 (early), the later would have been a 12342698. It would have to have been a GM kit used for these to be confirmed.
You might try to find some VSS-100 remotes.
Is there an FCC ID on the FOB? That should get you an ID easily for whatever package a dealer might have used, GM or other.
To '92 Dealer installed Keyless Entry-Programming
