How to build a engine with a supercharger?
Old Sep 2, 2002 | 08:06 AM
devilfish's Avatar
devilfish
Default How to build a engine with a supercharger?
what must i change to run high boost on my engine.?
This is going in.
Headers
ported heads
zz9 cam
miniram
And in the future I would like to run a supercharger. Is it enough to replace the piston with stronger ones?
Regards
Old Sep 2, 2002 | 11:27 AM
Cratzy's Avatar
Cratzy
Default Re: How to build a engine with a supercharger? (devilfish)
I would put in forged everything, just to be safe. Because when you put in a SC U most likely want to turn up the boost... :D
Old Sep 2, 2002 | 08:29 PM
kawboy5792's Avatar
kawboy5792
Default Re: How to build a engine with a supercharger? (Cratzy)
yep...id say go forged stuff, especially the pistons....its like pringles, once you pop, you cant stop :yesnod:
Old Sep 2, 2002 | 08:34 PM
bill mcdonald's Avatar
bill mcdonald
Default Re: How to build a engine with a supercharger? (kawboy5792)
You want to run forged blower pistons, and a lower compression ratio. this ratio will depend on how much boost you wish to run through it.
I would install forged rods as well.
I think the crank will be fine as cast as long as you dont try and spin it over ~6500 rpms.
There are a few LT1's with stock cranks making 600 flywheel HP.
To How to build a engine with a supercharger?
