vanity light problem
Old Feb 26, 2016 | 10:02 PM
Scott Lumbert's Avatar
Scott Lumbert
Default vanity light problem
OK I did search and didn't find anything. My 85 vanity light is not getting any power. The FSM says all the wires from the fuse the fuse is good. Does anyone know where the wire makes the split?
Old Feb 26, 2016 | 10:55 PM
HAD2HAV2's Avatar
HAD2HAV2
The wire plug for the vanity light in the sun visor is under the plastic piece where the Targa top bolts to at the windshield. Is this the light that is not working?
Old Feb 27, 2016 | 08:22 AM
Scott Lumbert
Yeah I pulled and checked the wiring there and I have the dash top off as well. I checked at the next connection which is just under the dash top.
Old Feb 27, 2016 | 03:33 PM
Scott Lumbert
The FSM says the vanity light is hot always. Or so I thought. It's switched from the key.
Old Feb 27, 2016 | 07:34 PM
HAD2HAV2's Avatar
HAD2HAV2
Need key on to get power to the visor light. Too easy to leave on and drain the battery. I'll double check.
Old Feb 27, 2016 | 08:21 PM
HAD2HAV2's Avatar
HAD2HAV2
Gauges fuse powers the visor lights. Check to see if you have power at the upper windshield connector.
Old Feb 27, 2016 | 09:37 PM
Hot Rod Roy's Avatar
Hot Rod Roy
So is that your answer? So you don't have a problem? I find it hard to believe your sunvisor vanity lamp is switched from the key. I believe the '85 vanity lamp is powered by the CTSY/CLK fuse, which is always hot.
I'm not sure what you mean by "Or so I thought." Are you looking at pg. 8A-52 in your FSM (lower left corner)?
Old Feb 28, 2016 | 03:46 PM
Scott Lumbert
Yeah. There is no problem. The book, on page 891 lower left says, hot all the time. But it's not.
To vanity light problem
