93 corvette frame to block ground strap
Old Mar 12, 2016 | 03:10 PM
Ryan Sevendaze Doyle's Avatar
3rd Gear
Default 93 corvette frame to block ground strap
i recently found out the gremlins in my car are most likely caused by the ground strap as it wasnt even connected to the block and was tucked into the fuel lines on the frame. I need to know where on the block i need to put this and if it needs anything else attached to it.... or if i could just ground it out and lock it down with a bolt. im new to the lt1 and have no idea. thank you for your help if you can...
Old Mar 14, 2016 | 02:20 PM
mrodoc's Avatar
mrodoc
I have a 1994. If we're talking about the same ground, mine is bolted to the bell housing to engine bolt, driver's side, second bolt from bottom.
Old Mar 14, 2016 | 07:14 PM
3rd Gear
is it just by itself or does it have other grounds with it? thank you i had an idea that it goes there....i looked underneath for a second and didnt see anything else.....
Old Mar 15, 2016 | 08:23 PM
mrodoc's Avatar
mrodoc
I should have mentioned that. The one from the frame, plus three others that come out of the wiring harness, I don't know what they go to. I found out the hard way, when I was changing my torque converter, I loosened that nut, and I didn't see the grounds. All four broke and I had to repair.
Old Mar 16, 2016 | 08:04 AM
3rd Gear
Default thank you so much you have no idea
i had a feeling about that but i didnt want to guess.... i did add a few other grounds on the frame but this is why the ecm doesnt work properly when that one is off.... thank you in going to take it apart today and try and get to it...did you do it from the bottom or through the side?
Old Mar 16, 2016 | 12:48 PM
mrodoc's Avatar
mrodoc
The frame attachment is reached through the wheel well. The bell housing bolt from underneath. The other wires, from the harness, all from the bottom.
To 93 corvette frame to block ground strap
