et vs weight
Old Mar 13, 2016 | 08:31 AM
preacher putz's Avatar
preacher putz
Default et vs weight
I need an educated WAG. Have a 96 collectors edition Lt1/auto
Yesterday did a best of 9.001 in the eighth , by removing 38 lbs, how much will this effect et? not looking for much, just need to be comfortably under 8.99
Thanks for your input
Putz
Old Mar 13, 2016 | 08:51 AM
antfarmer2's Avatar
antfarmer2
Go on a diet.
Old Mar 13, 2016 | 09:06 AM
TA's Avatar
TA
I think the old rule of thumb is a tenth improvement for every 100 lbs lost. I'm thinking you should easily be under 8.99 (in similar weather, with similar launch).
Old Mar 13, 2016 | 09:09 AM
grandspt's Avatar
grandspt
When I raced 1/4 mile track, for every 100lb loss of weight you decrease your ET by about 1/10th of a second.
Old Mar 13, 2016 | 08:44 PM
69427's Avatar
69427
From: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
Putz
Depends on where you take the weight out from. Any weight reduction will help the acceleration at the top end (simple F=ma), but taking the weight off the back or from up high (reducing weight shift to the rear) may reduce your traction component more than it reduces your mass/inertia component (ie: more starting line wheel spin and slower 60 foot times).
Old Mar 15, 2016 | 11:19 AM
Scott442's Avatar
Scott442
Can you post the time slip data? What water temp were you running at the time? I think it should run in the high eights without weight reduction. My stock 94 convertible with a 230 lb. driver has gone 8.93 with 170 - 180 degree water temp.
Old Mar 16, 2016 | 12:28 AM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
MY stock '92 has gone 8.89/80mph on a 2.06, 60' time. Furthermore, I did this at 4500' elevation on a 7000' DA. You need to work on the driver mod, I'd bet. Keep at it!
Old Mar 18, 2016 | 08:40 PM
ghoastrider1's Avatar
ghoastrider1
this post makes me think on the old argument over whether to have a full tank of gas for the traction or near empty for the weight reduction..same as keeping or taking off the spare tire.
To et vs weight
