Help!
Old Mar 19, 2016 | 11:04 AM
Justin Boyd's Avatar
Justin Boyd
2nd Gear
Default Help!
Im sorry I'm a corvette noob and just was wondering what would make, (what seems like) my entire driveline more around sometimes causing(get this) my crank pully to barely touch the beam directly in front of it when reversing and during braking, its a 1985 stock vette, 106,000 miles, just put a 90 vette transmission in it last night, shifts fine, drives decent but lots of driveline movement and noise, even sometimes when backing up when I brake I hear the crank pully hitting ?cradle? ? EVEN IN NEUTRAL while rolling slowly backwards..... beam direct in front.., im just trying to figure it out, sorry if this has been discussed somewhere else that I haven't found. Also the car was in a front end collision at some point but has been fixed. Thanks again for any help, slso I'm new to this forum so please be gracious Also does the 1985 have a transmission mount/crossmember?. Thanks!
Last edited by Justin Boyd; Mar 19, 2016 at 11:09 AM. Reason: forgot to ask a question.
Old Mar 19, 2016 | 02:13 PM
Hot Rod Roy's Avatar
Hot Rod Roy
Yes, the crank pulley (harmonic damper) is very close to the front crossmember. There's usually just enough room to be able to remove your serpentine belt! It sounds like you need new motor mounts.
Old Mar 19, 2016 | 07:43 PM
84Z51J's Avatar
84Z51J
I was going to say motor mounts as well, but then got to the part about a front end collision...mounts are the likely culprit, but have a good look underneath and make sure the frame isn't tweaked. Can't necessarily tell 100% with an inexperienced visual...but if something is visibly askew, at least you found it while parked.
Old Mar 20, 2016 | 10:46 AM
Justin Boyd
2nd Gear
Thanks guys I was hoping thats all it was, and my corvette is going to be a project/ handful so I will probably be asking more questions that I cannot find answers to, thanks again!
Old Mar 21, 2016 | 01:02 AM
Cliff Harris's Avatar
Cliff Harris
No. The rear of the trans/engine is held up by the C-beam, like so:
To Help!
