Hypertech chip issue?
Old Mar 19, 2016 | 02:17 PM
c489's Avatar
c489
Default Hypertech chip issue?
I have a 92 lt1 and it will surge idle and sometimes shut off when at stop lights or in traffic. i have a long list of repairs made to it but i just discovered i have a hypertech chip in there that i never knew about. how much could this chip be affecting my idle? i also have an msd opti with adjustable timing. unfortunately im not to familiar with comnputers so im not sure if those two have an conflicts. would i have to get the chip retuned? i changed injectors and plugs, wire, coil, icm, egr, opti, fuel filter. im lost any help is appreciated
its a 92 lt1 corvette with this chip
Old Mar 19, 2016 | 03:18 PM
THE 383 admiral's Avatar
THE 383 admiral
Pull. That hyper out along with the adapter. Sell it. Just install the factory prom. It's keyed. Can only go in one way. Unless the Factory Prom is fried?? NO need for that Hyper.
Old Mar 19, 2016 | 03:21 PM
THE 383 admiral
Hang onto the adapter. In the event. You add parts. A tuner can install a EEprom and burn. Leaving your Factory PROM original!
Old Mar 21, 2016 | 07:19 PM
c489's Avatar
c489
Yeah thats probably what I should do, only thing is stock prom goes for like $200 On ebay.
Old Mar 21, 2016 | 10:42 PM
THE 383 admiral
That makes NO sense. a typical 94 - 95 NON vette complete pcm. averages $50 - $100 in yards. And the lower model cars will work exactly the same. When re- flashed. And you only need the OE prom. I would burn a copy then. For a fraction of the cost.
Old Mar 22, 2016 | 07:38 AM
c489's Avatar
c489
I don't know what reflashed means of how to burn a copy
Old Mar 22, 2016 | 11:26 AM
THE 383 admiral
what is the deal with your factory Prom as pictured? What is preventing you from using it without that adapter and hyper EEProm?
Old Mar 22, 2016 | 01:10 PM
bjankuski's Avatar
bjankuski
Since you owned the car has it always surged and stalled? If not the chip is not the problem. I would suspect something else like an O2 sensor first.
Old Apr 14, 2016 | 02:16 PM
Troopshc's Avatar
Troopshc
1st Gear
c489 - Did you ever figure out what the problem is ? I just purchased a 92 vette that has that same chip, and Im having the same exact problem.
To Hypertech chip issue?
