Oil level sensor question?
Old Sep 4, 2002 | 12:53 AM
R23HTC's Avatar
R23HTC
Default Oil level sensor question?
I know this sounds strange, but how does it work? If it goes bad, does it stay on? Not come on at all? Mines lost the stuff around it, but I think it's still working, but I'm not sure. Anyway to tell without running an engine low on oil?
Old Sep 4, 2002 | 02:56 AM
Dan Parker '96's Avatar
Dan Parker '96
Default Re: Oil level sensor question? (R94 LT 1)
Luckily... GM provides a dipstick for oil ;)
Old Sep 4, 2002 | 03:17 AM
87Beast's Avatar
87Beast
Default Re: Oil level sensor question? (Dan Parker '96)
Thanks for reminding me Dan... sometimes I forget to check the oil. Us L98's don't get luxury of a low oil warning.
Old Sep 4, 2002 | 09:02 AM
R23HTC's Avatar
R23HTC
Yes I know. :rolleyes: I also know I have oil. My question was how does the sensor work?
Old Sep 4, 2002 | 09:32 AM
Goody's Avatar
Goody
Mine comes on when the oil gets about 3 drops low and stays on unless you cycle the ignition. So, I just turn on my ignition w/out starting, then turn it back to off and then start the car.....works like that.
I've changed my sensor thinking that it was a bad sensor because the low oil light comes on too often for my liking. Like right after an oil change when I know for a fact that I put in 4.5 qts of fresh Mobil 1. But, there it is shining in my face :mad . So, I spent the $40 for a new one and guess what? Yup, that damn light was looking at me again. So I just use the dipstick and be done with it. Figure it was around long before this dumn sensor whom has attended way too many sensitivity training seminars.
The sensor has a strange sort of float looking thing on the end of it, but is surrounded by the main body as well. I'm not sure if the float is used to measure voltage or resistance. I looked real close at the new one and studied the old one as well, and aside from the smell of oil and a stain couldn't see much of a difference from the outside. Both are GM parts.
Old Sep 4, 2002 | 03:21 PM
Red Dwarf's Avatar
Red Dwarf
Default Re: Oil level sensor question? (Goody)
When you change oil & filter try 5 quarts. I think that nay cure your problem
Old Sep 4, 2002 | 03:37 PM
Nathan Plemons's Avatar
Nathan Plemons
My light doesn't come on unti it's actually low. Might try putting in 5 quarts. Think about it this way, at any given moment there will be quite a bit of oil up in the motor while it's running. If it's a 16th of an inch over full when cold with 5 quarts, just fire it up and run it for a few minutes. Check it again. So long as the crank isn't slapping the oil you'll be fine.
I did have a broken sensor, came apart when I dropped the pan to get at the timing cover. It would "work" but it would come on for no reason and stay on until I cycled the key.
Old Sep 4, 2002 | 03:54 PM
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
Cruise-In II Veteran
Default Re: Oil level sensor question? (lou sylvestri)
Everyone is kind of dancing around it but not really providing an answer to the underlying question.
Does the sensor show the circuit open or closed when the oil level is low?
Is it a sensor that will come on while the engine is running or does it only look at the level at startup? If it works at runtime, how fast does the gauge react?
If the plastic cover at the tip of the gauge is broken off, but the sensor components are still in tact, will it set a code, work properly, or simply not function and not tell you.
Old Sep 4, 2002 | 10:20 PM
R23HTC's Avatar
R23HTC
Default Re: Oil level sensor question? (Vette92)
Thank you! :yesnod:
Old Sep 7, 2002 | 04:29 PM
R23HTC's Avatar
R23HTC
ttt
Old Sep 10, 2002 | 02:01 AM
R23HTC's Avatar
R23HTC
ttt
Old Sep 10, 2002 | 02:29 AM
merrick's Avatar
merrick
I didn't know there was one. I also put in only 4.5 qts at oil change and never had the light come one. I will have to look up more info on this sensor later.
[Modified by merrick, 1:34 AM 9/10/2002]
Old Sep 10, 2002 | 10:07 AM
Goody's Avatar
Goody
Only during startup. Else it would be on all the time due to oil being in the upper part of the engine. During high RPM useage I have received a low oil check guages light when braking really hard. No low oil light then.
The red check guages light will illuminate anytime oil pressure drops really low (<8psi).
Adding five quarts is not a good idea, but I do fill it up all the way to the top of the line on the dipstick. Still get the light......POS sensors....
Shows the circuit as an open when not enough oil in pan upon startup.
No it will not work when broken. (GM doesn't make money or working broken sensors, only non-working broken sensors). There are no codes that get set from this sensor. Just the idiot light. Guess I could unplug mine and see if the light comes on. That would answer the question about whether or not it illuminates when in a non-working condition.
Old Sep 10, 2002 | 11:46 AM
R23HTC's Avatar
R23HTC
Guess it's time to replace mine then. It's gotten to the point were it comes on every morning. If I shut the car off and restart it, it will go out. :rolleyes: Plenty of oil in the pan.
Thanks for the answers. :yesnod:
To Oil level sensor question?
