Low RPM+WOT rumble
Old Apr 4, 2016 | 03:51 PM
n8sh4de's Avatar
n8sh4de
Default Low RPM+WOT rumble
My corvette ('95 manual) has a strange Problem:
At low rpm and WOT, till about 1600 rpm the engine is knocking and rumbling. The problem gets worse the lower the rpm and is and at 1000rpm it even beginns at about 80% throttle.
Except from this, the car runs fine, it just needs a bit more fuel than before. High octan fuel decreases the problem.
Optispark, O2 sensors, fuel injectors, spark plugs and cables are new. MAF has been cleaned. The IAC valve seems to be lazy, but I don't think this will be the problem.
Before this started, I've alread had and still have a mysterious #24 VSS error.
Any ideas?
Max
Old Apr 5, 2016 | 10:31 AM
bjankuski's Avatar
bjankuski
Are the knock sensors functioning? I assume you are reporting detonation but are you sure there is not something loose that is rattling or knocking at low RPM high load?
Old Apr 5, 2016 | 12:12 PM
cv67's Avatar
cv67
St. Jude Donor '05
Are you lugging the engine trying to listen for the problem or drive it like that on a normal basis if so stop
Wish I could be of more help w/codes
Old Apr 5, 2016 | 01:24 PM
383vett's Avatar
383vett
You need to change your driving habits. I assume your car is a manual. Unless you're in first gear, wot or 80% throttle at 1600 rpm or lower in any other gear will cause knocking and pinging in most cars.
Old Apr 5, 2016 | 07:24 PM
n8sh4de's Avatar
n8sh4de
I don't know if my knocking sensors are working correctly but the engine shouldn't shake so bad even if they don't. High rpm are also no problem.
Before I had this problem the car accelerated well at this load conditions, but now it feels like trying to accelerate in 6 gear with 500RPM, not like 1500...
At 70% throttle now the car is faster than at 100%...
Old Apr 6, 2016 | 05:44 PM
Christi@n's Avatar
Christi@n
Any ideas?
Max
Loosen TB and IAC bolts gets air to sucked in, you may have a vacuum issue,
Though you mean your engine knocking and rumbling or is it just poor on low RPM?
Old Apr 7, 2016 | 07:20 AM
n8sh4de's Avatar
n8sh4de
Just low rpm or idle is ok, but together with a high gear and full throttle, the engine starts to shake and rumble.
Old Apr 8, 2016 | 02:41 PM
cv67's Avatar
cv67
St. Jude Donor '05
Wonder if you got one or more injectors going bad.
Is your EGR valve functioning properly?
Old Apr 9, 2016 | 11:47 AM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
No way. Not in any electronically controlled engine I've seen. That is the point of having electronic controls, and feed back like KS. Knocking at 80% throttle at 1600 RPM is unacceptable. Here is my LT1 at 100% throttle starting at 1000 RPM. No alarming or unpleasant noises/sounds or sensations at all....just a smooth pull.
I think the OP needs to post a vid of the symptom so that we can understand it better. Otherwise, we're just WAG'ing. Could be EGR, could be vacuum leak, could be injectors, plug wires, etc. etc. We need to understand the actual sound/symptom better.
Old Apr 9, 2016 | 01:35 PM
383vett's Avatar
383vett
What do you have, a diesel Tom. Your car makes 280 ft/lbs of torque at 1200 rpm? Full throttle in a higher gear at that rpm really stresses the lower end. That's why cars have transmissions.
Old Apr 9, 2016 | 02:33 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Nah, it's doesn't stress the bottom end. High RPM creates far, far higher stresses on the bottom end, than high tq low speed. Engine "lugging" is a psychological problem...not a mechanical one. As long as you have enough oil pressure (at low RPM), and controlled combustion, the bottom end will be fine, almost indefinitely.
Most modern 5.7-6L V8's Make ~300 lb-ft @ 1000 RPM. Nothing special about mine...other than I started my pull down low, so you can see that, where most people do not start a pull that low.
GM does their pulls from "down low", too....
Old Apr 9, 2016 | 06:21 PM
Christi@n's Avatar
Christi@n
Could be a bad ks too?
As far as I remember bad ks should have a code, try to make a code reading with a paper clip
Just too be sure
Old Apr 9, 2016 | 10:13 PM
93Rubie's Avatar
93Rubie
Considering this thread is going no where why don't we start somewhere.
You state it "rumbles" and such at low RPM AND WOT?!?!
Runs decent every where else. Higher octane fuel decreases the problem. This is correct right?
Sounds like it could be pinging. This can be caused a LOT of things.
Check fuel pressure at idle, WOT (snap test), etc...
Check your Opti-Spark for proper signals-Timing Issues
KS system operation
Overheating
Etc....
I posted a video series on this here.
https://www.corvetteforum.com/forums...eo-series.html
Old Apr 9, 2016 | 10:45 PM
desertmike1's Avatar
desertmike1
How are your temps behaving? Have you had a coolant recovery tank push fluid out? Have you had/have any cooling issues?
The reason I ask this is because I had a similar problem with my 95 making torque in the Low RPM range, it would Hesitate and stumble. This all starting happening after an overheat. Turned out I had leaking head gaskets.
Now I can pull pretty hard in 6th gear at 1200RPM and all of the Stumble went away.
Hopefully you have a simple problem like Fuel pressure etc.
Old Apr 11, 2016 | 05:24 PM
n8sh4de's Avatar
n8sh4de
Thanks for your replys.
I've made a video yesterday where you can see this strange behaviour.
Teperature, oil pressure, etc are all ok.
At 00:12 you can see what happens when I floor it, with the shifter starting to shake and a strange engine sound.
Btw, unplugging the MAF doesn't change anything, it even seems to be get worse then.
Max
Old Apr 11, 2016 | 05:42 PM
93Rubie's Avatar
93Rubie
https://www.youtube.com/watch?v=nDIIW7C2peg
Max
As much as that shakes, vibrates, and sounds. That is a misfire.
That can be caused by a TON of things. Time to start testing.
Old Apr 11, 2016 | 07:01 PM
n8sh4de's Avatar
n8sh4de
Thanks!
...I've already thought about this, but I can't explain why less throttle or higher rpms should cause a better ignition?
To Low RPM+WOT rumble
Old Apr 11, 2016 | 07:35 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
I feel that it's most likely an ignition issue. The higher the cylinder pressure, the harder it is for spark to jump a gap across a plug. So, when you've got your throttle more closed, you have lower cylinder pressure and the spark easily jumps the gap, ignites the mixture.
Open the throttle to WOT,cylinder pressure goes way up...spark doesn't want to jump that gap...it looks of other, easier gaps to jump. I'd look (at night or in a dark garage) for spark leak from wires, boots, etc. Another place for spark to short to ground is a fouled plug (unlikely on a modern engine but possible) and inside the distributor.
Your misfire looks rhythmic to me, meaning it's one cylinder that has an issue. If you agree that it's rhythmic, that eliminates the coil, ICM, coil wire, and you should focus on plug wires, boots, plugs, and dist cap.
Old Apr 12, 2016 | 06:32 AM
Christi@n's Avatar
Christi@n
I would say: try to make a code reading...
I think if trouble is electronic.. A code should be
Old Apr 12, 2016 | 10:12 AM
bjankuski's Avatar
bjankuski
