Rear Spring Bolt Size/Dimension
Old Apr 6, 2016 | 11:30 AM
RandomTask's Avatar
RandomTask
Default Rear Spring Bolt Size/Dimension
I can't seem to find a definitive answer in my research. I know the stock bolt has more than normal threading, but I'm hoping someone knows the exact thread/bolt length for the rear spring bolts (the ones that attach the spring to the A arm). Anyone have this bit of info?
Yes, its from being cheap. Rather go out and buy the individual bolts than the ~$30 for the 'drop bolts'.
Cheers,
Old Apr 6, 2016 | 01:32 PM
THE 383 admiral's Avatar
THE 383 admiral
Cheers,
the rear does not have A arms. I have a complete spare dana 44
If someone does not post. I will update. my guesstimate 8-3/4L ~ 11mm x 1.5
Old Apr 6, 2016 | 01:40 PM
383vett's Avatar
383vett
All you need is a bolt, a couple of washers, and a nylock nut. I took my bolt to a hardware store and swapped the metric one out for similar sized grade 9 standard thread bolt-nut assembly. Sorry, don't know what the size was.
Old Apr 6, 2016 | 02:39 PM
RandomTask's Avatar
RandomTask
Sorry, not A arm, but knuckle. Whatever that really long bolt is. The threads on mine are pretty rusted out and I wanted to replace it. . .
I'll pull it off this weekend when I'm back down at my shop. . .
Old Apr 6, 2016 | 04:43 PM
WVZR-1's Avatar
WVZR-1
The longest used "stock" are M14x2.0X225 - '91 & later, '90 and earlier were M14X2.0X192.5 It's generally assumed that 9/16 -18 are good for replacements and are less expensive. Buy however long you would like and either ny-lock nuts or castellated and drill for cotter pins.
225mm is something just short of 9" (8 7/8 thereabouts)
Old Apr 6, 2016 | 04:56 PM
THE 383 admiral
I just confirmed my 94~ 8.750L total 14mm my pitch gauge read & matched 2.0 OR as mentioned get a 9/16 SAE grade 8 or higher.
Old Apr 6, 2016 | 07:42 PM
BOOT77's Avatar
BOOT77
I bought some that were longer but weren't threaded enough, so make sure the new bolts have threads that start before the end of the stock bolts. My ideal spot was at the tip of the old bolts and the new ones the thread started just after.
To Rear Spring Bolt Size/Dimension
