Starts then dies
Old Apr 6, 2016 | 04:01 PM
Shawn84Vette's Avatar
Shawn84Vette
Cruising
Default Starts then dies
I have a 1984 Corvette that starts but immediately dies I was getting no spark so I change the control module cap and rotor
Old Apr 6, 2016 | 04:14 PM
bigtoys's Avatar
bigtoys
How long does it run before it dies? If it starts at all, you have spark. I would suggest checking fuel pump, filter, etc.; you may have a fuel flow issue after the initial starting prime from the FI system.
Old Apr 6, 2016 | 04:24 PM
Shawn84Vette
Cruising
Default Start and dies
It starts for about two seconds then dies and then after maybe the 5th to 6th time doing that she'll start and run for about two minutes and then die
Old Apr 6, 2016 | 04:34 PM
bigtoys's Avatar
bigtoys
When it runs for 2 minutes, is the "check Engine" light on? if so, pull your codes and start there.
I'm still thinking you may have a fuel flow issue. Most FI systems have an initial "prime" when you turn the key, which may be getting enough fuel into the cylinders to get you started, but is not sufficient to keep it running. I'm not sure if the Cross-fire system in your '84 works this way or not. Either way, it sounds like your system is not maintaining fuel flow.
Old Apr 6, 2016 | 04:36 PM
Shawn84Vette
Cruising
Thank you, I'll read the fuel pressure and see from there
Old Apr 9, 2016 | 01:20 AM
84 vett nm's Avatar
84 vett nm
1st Gear
Default 1984 c 4
My Vett turns over but dosnt start.replaced the fuel pump,fuel filter,relay for the fuel pump(?).The guy I got it from never had the ignition key so he jimmyed the ignition switch,wich he said it started and ran fine.But I have added gas TO the carbs starts but disnt stay on....Help please thats 84vettnm
Old Apr 9, 2016 | 03:42 PM
pcolt94's Avatar
pcolt94
After it runs for 2 seconds and quits, have someone crank the car and check for spark. Then you will know what area to work in.
To Starts then dies
