Cooling Issues? *HELP*
Old Apr 8, 2016 | 06:07 PM
MBianco86's Avatar
MBianco86
Default Cooling Issues? *HELP*
Hi everyone,
Recently I had a complete engine overbore and rebuild done in my 1986. I'm now 30 over and running a "355" instead of a 350. Before the rebuild, my car would run around 205-215 while cruising, and creep to 225-230 max in traffic. Now, regardless of traffic or cruise, the car steadily climbs until it reaches 247 or 248 and then the fan brings it back down to around 219, only to have it climb back up to that temp as soon as the fan shuts off. My 86 is a convertible and is only equipped with the standard equipment fan from that model year. I recently had it replaced and also had a new radiator installed. I am running a stock thermostat. I just purchased a manual fan switch and 160 thermostat thinking maybe it would help, but I'm no expert when it comes to engine cooling. Any ideas? Thanks!
Old Apr 8, 2016 | 07:30 PM
WVZR-1's Avatar
WVZR-1
Originally Posted by MBianco86
Hi everyone,
Whose radiator did you buy?
You are measuring your temps how? Do you know what the temp the fan actually engages? If all of the cooling system is confirmed good and fan/ECM etc, do as they're supposed to concentrate on the lower air-deflector, there should be a chin spoiler (most/many call it that) and it actually direct air towards the radiator/condenser module and of course it has the lower deflector that goes end to end. Important that it's there. The taller Z51 lower deflector actually helps. The actual lower center deflector, the upper deflector and the fan shrouds are important.
All of this + the lower bumper deflectors "in place and secured properly":
Name:  Early cooling.png
Old Apr 8, 2016 | 08:19 PM
BOOT77's Avatar
BOOT77
Overbore puts more heat into the coolant, thinner cylinders and a tad more surface area to absorb.
Make sure you AC is clean and fins not messed up if you still have it.
Did you change the waterpump? Correct rotation if you did?
edit: Did you increase the compression?
Old Apr 8, 2016 | 08:49 PM
HAD2HAV2's Avatar
HAD2HAV2
You may need a fan on the front AC condenser and the backside of the radiator, a pull and a push. My 88 C4 has both as stock. Not sure what option it was. Mine runs warn but not too hot.
Old Apr 8, 2016 | 10:29 PM
John A. Marker's Avatar
John A. Marker
Replace your water pump with a FlowKooler pump. That will bring the temps down. Pair with the 160 termostat.
Old Apr 9, 2016 | 10:45 AM
MBianco86's Avatar
MBianco86
Attachment 47970766
All bumper and air dam components are as they should be. I have all that in order. I ordered the radiator through a local auto parts store, and I have a temp gun I use to check readings. It seems the fan kicks in when the car is around 245. Way too hot for my tastes.
Old Apr 9, 2016 | 10:47 AM
MBianco86's Avatar
MBianco86
Waterpump is new and rotating properly. Coolant does flow once the thermostat opens. My AC compressor does not work however. It's been broken for many years. It's still hooked on my drive belt. Could that be an issue?
Old Apr 9, 2016 | 01:26 PM
John A. Marker
The FlowKooler water pump will flow 30% more coolant than a standard pump.
When I dropped in my ZZ4 in my 85 I installed the FlowKooler pump and it kept the temps on the freeway in the 185 range and seldom got to 220 in normal traffic.
Old Apr 9, 2016 | 01:48 PM
84Z51J's Avatar
84Z51J
You say the temp comes right down when the fan kicks on, so let it do so earlier--all signs point to the car wanting a lower temp fan switch. I run a 200 on / 185 off switch & 180 stat; your car should be happy with that combo if your new radiator is stock equivalent or better.
355 won't create that much more heat than a 350, unless you upped compression from stock too. 160 stat will do nothing better for you, except keep your car from running colder than 160, post-warmup, in chilly ambient temps.
If cooling remains insufficient after the switch swap, look into an auxiliary fan. Seems to me improved airflow is the solution, though a high volume pump couldn't hurt if you've got extra income to dispose of.
Old Apr 9, 2016 | 02:05 PM
WVZR-1's Avatar
WVZR-1
355 won't create significantly more heat than a 350, unless you upped compression from stock as well. 160 stat will do nothing better for you, except keep your car from running colder than 160, post-warmup, in super cold ambient temps.
If cooling remains insufficient after that change, look into an auxiliary fan. Seems to me improved airflow is the solution.
OP has a '86 and NO AUX so his fan is all controlled by the ECM. Fan I believe turns on @ 234 ( I believe) so maybe the OP just does an ECM CTS replacement and confirms the operation of everything with a scanner. He questions maybe performance so the scanner is NEEDED not just a maybe.
He needs to separately confirm the TEMP GAUGE sender and the cluster gauge. If gauge or temp ender are in error maybe there's actually no problem.
OP - an IR gun I've been told isn't very reliable at all when doing coolant evaluations. Other evaluations yes and I have access to a very good one. I use it in the house, around the car and nearly every place imaginable.
Old Apr 9, 2016 | 02:18 PM
84Z51J's Avatar
84Z51J
Ah, didn't realize '86 fans are ECM controlled, my bad! Add that to "things I learned today."
Good to confirm that there is indeed a problem
Old Apr 9, 2016 | 06:14 PM
MBianco86's Avatar
MBianco86
How were your temps before you installed the flowkooler? That might be my solution. Maybe it wants more coolant.
Also, I'm running regular Prestone 50/50.
Old Apr 9, 2016 | 06:15 PM
MBianco86's Avatar
MBianco86
How should I go about confirming the sender? Thanks! I appreciate all the help I'm getting. You guys rock 👍🏻
Old Apr 9, 2016 | 06:17 PM
MBianco86's Avatar
MBianco86
I'm thinking maybe an ECM tuning to that setup could work. If I could keep it in that range I'd be happy. If not, an Aux fan is definitely a viable option.
Old Apr 9, 2016 | 06:48 PM
WVZR-1's Avatar
WVZR-1
How should I go about confirming the sender? Thanks! I appreciate all the help I'm getting. You guys rock ����
Do you have the FSM? See 8A-82 for diagnostics,
A typical replacement gauge sender is: 100º F -- 1250-1600 ohms, 220º F -- 138-156 ohms,
The CTS for the ECM is pretty much done to this table. You'll find discrepancies from time to time but I believe it safe to assume these or very/very close:
http://pe-ltd.com/assets/coolant_temp.pdf
In your FSM Check CODE 14 in 6E3-A-35 and there's a chart included there.
With a scanner compare what the CTS sees vs. the dash unit. You could supply the dash gauge withe similar resistance values as in the temp sender and expect to see similar cluster readouts. Some year FSM actually may have the OE spec listed in a similar table.
6E3-C12-3 for cooling fan diagnostics.
Old Apr 10, 2016 | 01:10 AM
BOOT77's Avatar
BOOT77
I'm talking bout the part in front of the radiator, AC condenser. Make sure it's clean and the fins aren't all folded over, I've seen some that were pretty hammered by rocks.
Old Apr 10, 2016 | 01:54 AM
desertmike1's Avatar
desertmike1
^^ This gets widely overlooked! from a casual observation this coil may look good, but if you Back-lite it, and look through it from the opposite direction it may be loaded up with embedded bugs and you name it. Mine was so bad it took hours of cleaning to get it right.
To Cooling Issues? *HELP*
Old Apr 10, 2016 | 10:54 AM
mtwoolford's Avatar
mtwoolford
between the A/C condenser and radiator I spent several hours picking out several thousand dead bugs, grains of sand and who knows what; I would also suggest using brake cleaner to dissolve / remove any film that has built up on the fins and tubes
Old Apr 10, 2016 | 11:05 AM
MBianco86's Avatar
MBianco86
I'll take a look this morning! Thanks!
Old Apr 10, 2016 | 11:59 AM
John A. Marker
Temps were 15-20 degrees hotter.
