Rear Hubs loose
Apr 11, 2016 | 09:19 AM
Rear Hubs loose
There is some play in the rear hubs on my 1996 C4.
Im not sure what needs replaced.
What do I ask the part store for: hub, bearings?
Apr 11, 2016 | 09:25 AM
Quote:
Originally Posted by
2ooo-C5
If you elect to replace - hub or bearing. The'll get it.
Buy a pair of these from the dealer if you decide to do the hub and bearing.
GM# 14076924
Apr 11, 2016 | 03:44 PM
Make sure the play is in the wheel bearing (hub) and not just a loose or worn suspension part. It's easy to confuse them.
Apr 11, 2016 | 05:02 PM
Apr 11, 2016 | 10:29 PM
For what it's worth, I thought one of mine had play in it but torquing the axle nut to 160 ft-lbs fixed it.
Apr 12, 2016 | 12:51 PM
jv9999
160? really.... mine are torqued to 105.
Is 160 safe?
Apr 12, 2016 | 02:51 PM
jv9999
For how long.
Apr 12, 2016 | 03:30 PM
2ooo-C5
Is 160 safe?
Rears get debated frequently - the spec' for rears is 164 lbft in nearly all later FSMs. Some say that's been increased in a TSB, I ain't ever seen it and I believe they're getting confused with a later generation TSB regarding rear hubs. Never looked.
Apr 12, 2016 | 09:33 PM
antfarmer2
For how long.
It's been over a year now.
Apr 12, 2016 | 09:50 PM
All better.
New hubs had sealed bearing so no seals were needed.
