Losing coolant. Afraid
Old May 2, 2016 | 03:20 PM
  #101
desertmike1's Avatar
desertmike1
Originally Posted by mlm0
If I find that I do have bent rod, can it be straighten? If I have to buy new Rod can it be fitted on same piston and not have to replace rings or connecting rod to crank bearing, I don't want to pull engine and have machine work done. I was just thinking that compression test will not tell me if Rod is bent, because I have blown head gasket anyway After heads are off, I plan to use magnetic based dial micrometer to determine if all Pistons rise the same when engine is rotated. Will I most likely be able to see the area where gasket is blown once it's removed? Sorry for so many questions, but I'm new to all this. I'm hoping what I have read is correct, that being that a hydrolock because of coolant in cylinder causing the engine not to rotate is not enough force to bend Rod. What I don't understand is why after several times of trying, it would all of sudden start cranking and start up. Tommorrow I am going to pulled plugs, tape paper towel over holes and try to determine just which cylinder or cylinders are affected before I pull heads
Bent Rods don't get re-straightened, they get tossed!
Old May 6, 2016 | 01:50 PM
  #102
mlm0's Avatar
mlm0
Pictures of my number 7. Very wet with coolant after setting for about 4 days. I must not have been doing combustion or pressure test correctly, or they would have revealed a problem
Old May 6, 2016 | 05:52 PM
  #103
VikingTrad3r's Avatar
VikingTrad3r
Oil Producer
hg time!have you got the time space to do it?
Old May 6, 2016 | 05:55 PM
  #104
david1988c4's Avatar
david1988c4
Originally Posted by desertmike1
bent rods don't get re-straightened, they get tossed!
lol
Old May 6, 2016 | 05:58 PM
  #105
mlm0's Avatar
mlm0
I have the time and garage. Don't have the experience, but have FSM and this forum. I am going to just take my time and do a little at a time. No other choice? Not going to pay 3500.00 to have it done. The only areas that I really worry about are installing distributer correctly and lifter adjustment
Old May 6, 2016 | 06:33 PM
  #106
desertmike1
I'm glad to see you muster up the courage! this really won't be all that bad..
Old May 6, 2016 | 08:38 PM
  #107
Joe C's Avatar
Joe C
believe it or not, that's the easy part!
